Old 05-06-2004, 02:28 PM   #1
TSB
Default XXX BK2 Set up info...
I am curious what set ups are out there. i have ran the drake set up and didn't like it. I am looking for a set up that is planted and steers with the front of the car not the rear...
TSB is offline   Reply With Quote
Old 05-06-2004, 02:54 PM   #2
Trader Rating: 20 (100%+)
Send a message via AIM to Jamie Fredericks Send a message via MSN to Jamie Fredericks
what surface and or where do you run to give us a better understanding on what you need?
Jamie Fredericks is offline   Reply With Quote
Old 05-06-2004, 03:48 PM   #3
yea what kind of track do u have?
is it low bite medium bite highbbite or bluegroove
craziracer is offline   Reply With Quote
Old 05-06-2004, 08:46 PM   #4
Aaron Waldron's Avatar
Most setups work at most tracks, 90% of off-road is just tires.
When I get home from Vegas I'll post my standard setup.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 05-26-2004, 11:40 AM   #5
RCGaryK's Avatar
I saw Drake's on the Losi site, but what's a good neutral setup for Socal for the BK2? Tires and Gearing for Stock?
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 05-26-2004, 03:27 PM   #6
Tires for SoCal..M3 Square Fuzzies when the track is wet, Pink X's when it dries out.
I'd start gearing a monster at 20/82. All the setups listed on Losi's website are for indoor clay tracks like SoCal (except Cree's grass setup).
I still don't know how my buggy is setup..hopefully I'll remember to ask my dad tonight.
www.liverc.com
Old 05-26-2004, 05:08 PM   #7
Default On Power Push
I'm new to electric after doing only nitro for the last year. I run at Socal and have used the Brian Kinwald setup and currently using Drake's setup. I'm experiencing what seems to be A LOT of on power push. What would you suggest as starting points to lessen this affect? I've used the x2000 red and PL's Square Fuzzies M3, but both have a similar affect. Thanks.
GMorrisette is offline   Reply With Quote
Old 05-26-2004, 05:34 PM   #8
What front tires are you using? Make sure they're whatever the fast guys recommend (I don't know anymore..been a LONG time since I've been to SoCal).
Try going to the long arm in the front, that should give you more steering.
www.liverc.com
Old 05-26-2004, 05:58 PM   #9
I'm using the one's that came with the kit which are silver compound. I'm unsure of the name though.
Old 05-26-2004, 07:36 PM   #10
Oooh..that could be it right there.
Pink fronts might be better, just talk to the fast guys at SoCal. I know for a while, the Losi guys were trying R3 fronts..so you'll just have to ask around.
www.liverc.com
Old 05-26-2004, 08:04 PM   #11
RCGaryK's Avatar
I know talking with someone earlier today he said to run 7202 silvers. I'm just shocked that Pink tapers and prescrubs wouldn't be what to run.
HorizonHobby.Com
Old 05-28-2004, 11:19 PM   #12
nutfluff's Avatar
Send a message via AIM to nutfluff
Default SoCal Setup
I just converted from a B4 and loooooove my BK2. I modified Drake's set-up a little and my car is HOOKED!
The 7202 silvers is what everyone is running in the front but instead of the stock foam squeeze a rear foam into the tire. You might have to round out the edges for a clean fit. I use Pink X's in the rear with Trinity grey foam. Aaron was right about changing the front arms long for steering. Other than that, I use the stock springs with AE 32.5 oil all around. For the rest just go off of Drake's SoCal set-up...
Give it a try.
nutfluff is offline   Reply With Quote
Old 05-29-2004, 01:35 AM   #13
Thanks everyone. I'll give some of these a try tomorrow.
Old 05-31-2004, 09:54 PM   #14
RCGaryK's Avatar
Well I did run at SoCal Friday night and I didn't particularily care for the 7202 front tires like you guys suggested. The car just pushed soooooo bad. I ended up going back to pink 3-rib prescrubs with proline firm inserts and then had great front grip but it didn't unbalance the car too badly. I didn't like the Pink X's, but there was nothing that I could get to hook up any better. I tried Red and Pink X's and Tapers, but the track was just soooooo dry and sandy. If I was over agressive on the throttle it would bite me, but overall it was good. I just wouldn't get the rythem over the doubles/whoops section. Oh well, all in all it was a fun night.
HorizonHobby.Com
Old 05-31-2004, 11:57 PM   #15
nutfluff's Avatar
IMHO If you were having that much trouble, tires were the least of your problem. I ran those on Wed night and was dialed...look to other areas in your set-up......
OS .21 VG INFO jatoman1992 Nitro Off-Road 2 10-03-2007 05:02 PM
some help/info please wingspan Electric On-Road 6 03-13-2005 04:56 AM
some info on an tc cyrrus Canadian R/C Scene 0 03-05-2005 10:41 AM
thanks for the info [[[ww]]] R/C Items: For Sale/Trade 0 06-18-2003 09:42 PM
3PK info xray vision Australian Racing 48 06-09-2003 03:52 AM
