Slash 4x4 Overtrays> Good or Bad >
Old 05-16-2010, 12:58 PM
Suspended
Trader Rating: 7 (89%+)
Default Slash 4x4 Overtrays> Good or Bad
Hey guys, I have been thinking about getting one but havent really seen to many of them out there. Just wondering if they might overheat the motors and esc or not. I run a mamba max pro with a hv motor. Let me guys. Thanks
diesel32x is offline
Old 05-16-2010, 06:56 PM
Substance's Avatar
Depends on what temps you are getting currently with the gearing you have. I would add 20 degrees conservatively on top of that temp and gauge from there.
This is of course info for the motor, as the ESC should not have a problem with it. If you use a heatsink designed for a 550 it should counteract the temp spike from the overtray.
Whether they are good or bad is entirely debatable. I personally would go a different route.
Substance is offline
