Soldering tips
Old 05-14-2010, 09:02 PM
kodiakbear7070's Avatar
Default Soldering tips
What soldering penciel and solder is best to use. I have a 25 watt soldering penciel and it realy seems to not get the job done so I was curious to what others was useing
kodiakbear7070 is offline
Old 05-14-2010, 09:20 PM
forwardonly's Avatar
I have a 40W Weller pencil that does OK. Keep the tip clean, use flux, and don't use too much solder. If the iron is not hot enough to get the solder flowing very quickly, then you need to get a different iron, or clean the tip. There are a lot of videos on how to solder correctly.
forwardonly is offline
Old 05-14-2010, 09:40 PM
40w is the lowest you should go. I have a 25w pencil too but got a friend to solder my Dean connections on with his 40w pencil. 25w seems to be for small jobs like circuits...
nexguy is offline
Old 05-14-2010, 09:49 PM
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
For small wire I use a 40 watt pencil iron , but for heavier gauge wire and things like battery tabs I use a Weller 100/140 watt gun .
BashemSmashem is offline
Old 05-14-2010, 09:50 PM
RcRacing4Ever's Avatar
Get a Hakko... the best 100 bucks I spent 5 years ago..now I see them going for 80 bucks & that includes a wrap.
RcRacing4Ever is offline
Old 05-14-2010, 11:13 PM
losi_racer's Avatar
Trader Rating: 25 (100%+)
thats what im getting
losi_racer is offline
Old 05-14-2010, 11:52 PM
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
tough to spend $80+ on an iron but after having the best in the past (Hakko) and then using something else it's worth the money......have a nice 936 now
racer1812 is offline
Old 05-15-2010, 02:25 AM
Trader Rating: 22 (100%+)
Yup! Get a Hakko. Forget the rest
Honu is offline
Old 05-15-2010, 07:03 AM
Is the checkpoint iron a copy of the hakko? I have heard good things about it. I have got to get a new iron.
Old 05-15-2010, 04:40 PM
I was wondering the same thing on the check-point and would also like to know about the KOMEC 936<---its on ebay so you know how that is u get what you pay for
Old 05-15-2010, 04:42 PM
MotoGod's Avatar
Trader Rating: 112 (100%+)
I got my Hakko 936 out here used for $50 and it was the best purchase I have EVER made for RC stuff. The Hakko just rules....
MotoGod is offline
Old 05-15-2010, 05:03 PM
Substance's Avatar
I have a TC 60 watt and it is awesome. Almost identical to the 936.
Substance is offline
Old 05-15-2010, 06:44 PM
chris c's Avatar
Trader Rating: 60 (100%+)
i have this weller.......had it for past 4 years works great and heats up in 2 mins
http://www.cooperhandtools.com/brand...c=037103191311
chris c is offline
Old 05-15-2010, 08:33 PM
nharkey85's Avatar
Trader Rating: 12 (93%+)
I picked up this unit back round October last year. Gets the job done no hassle, but I definitely need new tip for it. Honestly believe its at max temp in under 2 minutes, absolutely no longer than 2.
http://www.radioshack.com/product/in...ductId=3132686
nharkey85 is offline
Old 05-15-2010, 08:44 PM
quadracer111's Avatar
Dont use to thick of solder. I have an 85watt iron and it doesnt work with to thick of solder and thin solder is impossible to find here
quadracer111 is offline
