Soldering tips
Old 05-15-2010, 09:19 PM
  #16
Timbulb's Avatar
I've used many cheap soldering irons and they've all worked fine. My personal 4 rules are this...
1. use a paste flux (even if the wire says it has flux in it.)
2. keep the tip clean
3. pre-tin everything
4. always have some solder on the iron, this helps transfer the heat better
If you're skipping one of those, you're making life hard for yourself.
Timbulb is offline
Old 05-16-2010, 07:17 AM
  #17
I purchased several weller irons and finally purchased a used Hakko What a life of difference made life so much easier and now look at soldering with no problem, try to pick one up for 50 or 60 bucks
swiftlion is offline
