MMM Novak 4.5 ???
Old 05-14-2010, 05:54 PM
Trader Rating: 89 (100%+)
Default MMM Novak 4.5 ???
I was looking to run this combo in my Hyper 10 SC. Will the Novak work with a Mamba Monster? Or will I need to get a Mamba Pro to run it sensored?
I have heard that you can run sensored motors without the sensor wire connected with no issues............does this hold true with the Novak motor?
Stonefish is offline
Old 05-14-2010, 06:12 PM
Mamba monster is "sensorless" only while the MM pro is both sensorless or sensored modes.
rinferno is offline
Old 05-14-2010, 08:55 PM
I understand that, what I need to know is if the Novak can be run as a sensorless motor with the mamba monster or will it create issues with the ESC?
I was told most sensored motors could also be run w/o the sensor wire connected......is this true or do I need to buy a MM pro?
Old 05-15-2010, 06:54 AM
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Stone fish View Post
I understand that, what I need to know is if the Novak can be run as a senseless motor with the mamba monster or will it create issues with the SEC?
I was told most censored motors could also be run w/o the sensor wire connected......is this true or do I need to buy a MM pro?
It should be fine with the MMM ESC , you might want too turn the timing too 0 degree . Just tuck the sensor wire up somewhere it wont get damaged .
BashemSmashem is offline
Old 05-15-2010, 12:10 PM
Thanks for the reply, I will set the timing to 0 and give it a shot.
