Associated 1/8 pinion gear set screw
Does anybody know where I can get a set screw for a 1/8 associated pinion gear? I've looked everywhere and maybe I'm typing in the wrong words in google or something, but I cant find it!!! I need a few lol
Try Ebay, you may need to purchase the small lot of parts that the set screw is mated to. Also you may get a few in a Tony's screw kit or a similar kit.
If you have any hardware stores in your area, check them out to see if they carry bulk screws. If I remember right, the 1/8 pinions use a 3mm set screw.
For Mod 1 pinions the set screws are 4mm diameter and 4mm long with a 2mm hex. Pretty standard across the board.
