gearing ?
i got a 19t 48p pinion gear and a 86t spur gear. what gearing would be best for bashing. i don't just want low end power. i need some speed still. i ordered a 18t pinion gear. i waiting to put that on and see how that works out. i mean its ok right now with the 19t and 86t. im just trying to find the perfect ratio. i want low end power/torque, but also some high end speed. but if i had to do a ratio of low end/high end, im looking for maybe 60/40 with the 60 being low end.
Originally Posted by ckblood05
(Post 7390399)
Originally Posted by Chill_Will
(Post 7391113)
The 18 is going to give you more low end but not top. What truck do you have and what motor and esc are you running?
ok, i got my 18t pinion gear today. does the motor run cooler with lower gearing?
