What do i use to remove paint? >
Old 05-10-2010, 08:45 PM
88NATE's Avatar
Default What do i use to remove paint?
Does anyone know what to use to remove paint from the body?. I want to try to remove some paint off on a certain area so i can repaint it, any help would be appreciated!. thanks
88NATE is offline
Old 05-11-2010, 12:27 AM
*Chrominator*'s Avatar
Trader Rating: 19 (100%+)
Just do a search, that's what I just did , and came up with this one.
Here's the one that has the most post , there's also some in the Paint section.
http://www.rctech.net/forum/electric...paint-off.html
I have used Brake fluid, (NOT BRAKE CLEANER) and had great results. Depending on how thick the paint is, it may take a few applications and some elbow grease, but when done the body looks like brand new, with no clouding or fogging of the Lexan.
*Chrominator* is offline
Old 05-11-2010, 04:56 AM
Trader Rating: 21 (100%+)
I've used brake fluid as well, but am used to letting it sit and soak in the inside of tehshell to pull th epaint. You may have to get creative to use it on just a particular area.
Duster_360 is offline
Old 05-11-2010, 11:12 PM
88NATE's Avatar
Thanks guys!, i did think of brake fluid but i thot it would be to harsh against the plastic and eat it! but now that i hear it works i'm going to give it it a shot. thanks again!
88NATE is offline
Old 05-12-2010, 02:58 PM
sLaSh It UPP's Avatar
stp brake cleaner work the best
sLaSh It UPP is offline
Old 05-12-2010, 04:54 PM
Derry's Avatar
Trader Rating: 27 (100%+)
I tried acetone once...(paint comes right off) hehe. was left with a melted/cracked mess of a body.
Derry is offline
Old 05-12-2010, 07:46 PM
the5's Avatar
Trader Rating: 42 (100%+)
i use easy off works well
the5 is offline
Old 05-13-2010, 11:25 AM
Trader Rating: 20 (100%+)
brake fluid, time and patience will work
storytyme is offline
