Old 04-28-2004, 05:25 PM   #1
karter's Avatar
Send a message via AIM to karter
Default Fantom engine settings
What are the factory settings for the fantom fr12 nitro engine?
Karter
karter is offline   Reply With Quote
Old 04-28-2004, 09:16 PM   #2
SlobbaTech's Avatar
I don't remember what mine came at but mine run at 2.5 out on top and 1.5 on bottom from closed, the rear exhaust is same but bottom is more like 1 & 1/8 out on bottom.
SlobbaTech is offline   Reply With Quote
Old 04-28-2004, 09:18 PM   #3
karter's Avatar
I was guessing it was flush with the carb on LS and i was thinking 2.5 out on HS does that sound about right?
Old 04-29-2004, 12:01 AM   #4
Aaron Waldron's Avatar
Thanks Jesse!
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 04-29-2004, 11:20 AM   #5
SlobbaTech's Avatar
Flush is close and should be somewhat in the ballpark, but everyone's idea of flush might differ, so just use number of turns out from closed b/c the numbers I'm giving you will be right on. For SE and RE motors 2.5 is usually best unless it's cold or the air is dialed, in that case it's more like 2.75 or closer to 3 on top. I've never had to run it lower than 2.5 out on the top. On bottom SE is 1.5 out, RE 1 & 1/8 on bottom. Some carbs might vary a little for needle settings, usually only effects bottom needle and in that case most of the time it will need to be set a little leaner like 1/8 turn on bottom.
Base settings for Force 25 engine mutley001 Nitro Off-Road 1 02-06-2008 02:49 AM
Fantom Dyno Settings Mike 415 Electric On-Road 0 12-08-2006 08:31 PM
Engine settings???? sancho Electric Off-Road 2 07-29-2005 04:19 PM
fantom carby settings. Team-RTR Onroad Nitro Engine Zone 3 08-23-2004 11:31 AM
engine settings? Isolate Nitro On-Road 5 05-17-2003 01:04 AM
