Deans between motor and ESC better >
Old 04-27-2004, 02:56 PM
Richy89's Avatar
Default Deans between motor and ESC better
If i put deans between my motor and my ESC will i get more power??
Is it worth it. dose it give you longer run times???
Richy89 is offline
Old 04-27-2004, 03:10 PM
mattyk6's Avatar
Putting Deans between the motor and the esc will only help if you are currently using bullet connections or some other connector. The best connection between the ESC and the motor will be a straight connection, having the ESC's wires soldered to the motor.
mattyk6 is offline
Old 04-27-2004, 03:11 PM
Richy89's Avatar
What are bullet connections???
Richy89 is offline
Old 04-27-2004, 03:17 PM
Bullet connectors are the connectors that come on sport level escs and motors that come with rtr or beginner cars they are the kind that have a piece of clear rubber that slides over them. Switching to deans would help if you're currently running bullet connectors. It will make no real diffrence between just soldering the wires to the motor or having deans in between. Deans claims that their plugs have less resistance than an equivalent piece of 12 guage wire. The only thing that will cause resistance is the extra 2 solder joints on each wire.
AE Racer is offline
Old 04-27-2004, 03:48 PM
DOMOisCOOL's Avatar
Deans between motor and ESC are for people that run multiple classes at a race or people that want to swap out their motor faster.
DOMOisCOOL is offline
Old 04-27-2004, 04:01 PM
personally i think deans are harder to put out...i think its faster to use a soldering iron but u need experince with the iron i would start with the deans because its is much better then those garbage bullet connectors
craziracer is offline
Old 04-27-2004, 05:11 PM
17driver's Avatar
Direct solder to the motor is the way to go.
17driver is offline
Old 04-28-2004, 10:51 AM
Richy89's Avatar
OK im not going to direct sodder my motor to the ESC because i do change my motor often. But will i be able to tell the difference if i put deans instead of bullet????
I put deans on my battaries and charger and esc and i could tell a big difference. I got longer run times and more power.
Richy89 is offline
Old 04-28-2004, 11:00 AM
Tech Legend
Cain's Avatar
Trader Rating: 251 (100%+)
you may get better runtime with the deans versus the bullet connectors.
As for deans versus direct solder, you probably wouldn't notice a difference.
I used to used to run connectors on my motors all the time, never had any issues.
Cain is offline
Old 05-08-2004, 08:27 AM
Dude, whether you change motors out alot or not, direct solder is still the best way to go. It is nothing to take a soldering iron, touch it to where the leads attach to the motor, and thats it, motor removed. A little flux, tin the tip, and presto, new motor back in. The thing is, those connectors are so big and bulky, that it is not the fact that they weigh anything, but the fact that when they are combined with all the other connectors and wires you got under the body, it can be a mess, so if you can eliminate a connection, why not. One word of advice, if you invest in a nice soldering station, it will be one of the best rc investments you will ever make. I picked up a top of the line, used, older, Ungar soldering station a couple months ago on ebay, for less than 50.00, and the thing rocks. Super hot, and it takes a split second to create an awesome " weld. " I used to use a big, bulky, quick-on, soldering " gun ", and I was always messing stuff up. Good luck!
Scott
wobbergoober is offline
Old 05-08-2004, 09:36 AM
Tech Legend
Cain's Avatar
Just go ahead and put the deans on the motor and esc. They are not that bulky, I ran powerpoles which are more bulky than the deans and never had any issue.
Cain is offline
