Opinons on the LRP SPX8 >
Old 05-26-2010, 12:36 AM
  #31
What up?'s Avatar
Trader Rating: 14 (100%+)
Originally Posted by JPKinsella View Post
I have been running profile 2 on throttle and profile 1 on on dragbrake and 0 on brake because I use mechanical brakes. 15/48 gearing, extended pinion no clutch on a losi buggy. Has worked flawlessly for weeks nice smooth power!!!
sounds good.
What up? is offline
Old 07-10-2010, 11:46 AM
  #32
Default spx8 external bec
Originally Posted by cpatel529 View Post
If I am not using the built-in BEC in the SPX8, where do I connect the wire that is labeled as the BEC input. It connects to a switch and then to the ESC.
Will probably either use an external BEC (like the Novak that was mentioned) or get a separate receiver battery.
Ditto on this question??? If I use a CSE BEC where do I connect the wire that is labeled BEC off the lrp switch??????
Pics anyone???
I know how to wire the CSE from the Battery leads and to pull the red wire off the ESC------but what about with the LRP and the BEC switch wire????
HELP
dapcohobbies is offline
Old 07-11-2010, 01:14 PM
  #33
KNikoloau's Avatar
Thumbs up Spx8 External BEC
Hello there,
If you want to add an external BEC to spx8 configuration the only thing you have to do is NOT CONNECT the small black cable from the switch nowhere.
This is the midle red cable on your radio connector so there is no need to remove it at all cause it is not connected anywhere.
So put your external BEC and connect it on your radio and you're on and running...
KNikoloau is offline
Old 07-11-2010, 01:53 PM
  #34
i've got a solution, A.E., get off youre wallet's and give us a REAL 1/8th E.S.C. this current A.E esc is just nothing but a headache for alot of user's.
charly71 is offline
Old 07-11-2010, 05:25 PM
  #35
brickshouse's Avatar
Hard to do when you sleep atop $100 bills....
brickshouse is offline
Old 07-11-2010, 05:27 PM
  #36
So if i use a receiver pack, i dont have to do anything with the 'other' black wire out of the on/off switch? Will it still turn on/off?
Old 10-01-2010, 02:07 AM
  #37
Ostach24's Avatar
Trader Rating: 88 (100%+)
Switch companies garbage.
Ostach24 is offline
