to warm for a lipo?
to warm for a lipo?
On my tekno converted MBX6-t with a 2200kv MMM my 5800mah 30C zippys are getting to 110* at the end of a run (cut off at 3.3v)
do you guys think i should gear down im running a 15 tooth with no clutch or brakes.
You'll get some different answers on this. IMO that's fine. My softcase LiPos will come off around 109F, similar to yours. Hardcase packs will temp cooler because there's space (air and/or foam/tape) between the LiPo itself and the hardcase, so if you read 110F on the hardcase, the cells are a bit hotter.
Are the packs puffing? If not, you're fine. Mine will sometimes puff just slightly after runs on hot days. They still perform great.
