? about front wheel not spinning freely
ok, i put all new bearings from duratrax and rpm bearing carriers all four corners. the left front wheel spins great. the right front wheel don't spin nearly as good. i was driving it on my driveway and road, and noticed it drifts to the right when going straight. so i took the wheel off, took the axle out and checked everything. it all seems fine just like the other side. when i loosen the wheel nut, it spins a lot better. but all the wheel nuts are tightned the same. any ideas?
My Losi does that with certain wheels I put on it. Just loosen the nut 1/8 of a turn if that and let it be. It's not going to be a problem.
Originally Posted by klaymon
(Post 7302321)
Try switching just the wheels and see if the problem follows the wheel or the axle. Mine is entirely wheel dependent. If I have my rib tires on it, one of the wheels "sticks". When my taper pins are on, no problems.
(Post 7302754)
I would double and triple check that all parts are straight and in tact.
Originally Posted by storytyme
(Post 7306489)
Did you try what klaymon suggested--just loosening the nut a bit and a little locktite?
You don't need Loctite. As long as you have a locknut on the axle and the nylon part of it is engaged on the threads it's not going anywhere.
Originally Posted by bowl806
(Post 7307243)
(Post 7307265)
cool-- Glad it worked!!
