How much does your 2wd SCT weight ?
Trader Rating: 19 (100%+)
How much does your 2wd SCT weight ? Not that it is that important, I'm just curious.
I built a costume Losi XXX-SCT which you can see here, in this thread, http://www.rctech.net/forum/electric...rse-truck.html
and I'm a little shocked at how much heavier it is over my MF2.
Besides the Associated SC10 bumpers, body mounts, battery strap, and a SCT body, I had to use the center section of a T4 Chassis, to join the two halves of my Losi chassis together with screws and epoxy, which is probably the only real added weight.
I noticed that the ROAR minimum weight on a 2wd SCT is 2098gr. or 74oz.
I'm assuming that is how much a stock RTR Slash weights with a battery.
My MF2 weights with a 5000 Lipo bat. 1774gr. or 62.311oz. (ROAR min.is 60.oz)
My SCT weights with out a battery..1967gr. or 69.09 oz.
and it weight with a 5000 Lipo bat...2276gr. or 79.944oz. (ROAR min. is 74oz)
Which means it weights 5.944oz over ROAR min. which sounds like a lot to me, does a Slash weight a lot less than a SC10 ?
I guess I'm just curious to see how much all of the other SCTs weight with or with battery's.
So if you can, post up your weights with and with out your battery's.
Thanks Chromie.
Thanks Chromie.
Slash with 4 oz and 2s lipo
Hey Guy's I'm sorry for starting this thread, I'm so use to dealing with kits , I forgot that these are all RTRs that come with everything, and all I had to do is look up the specs. , to see what they weight.
Any way that's pretty hard to believe that this thing at 1967g is lighter than the SC10 at 2082g.
Thanks for all the responses.
I know my blitz with a 2s weighs in at 4.3 and my durango with a 62 gram nose weight and a 2s weighs in at 4.12. they weigh us after every A main
My FT SC10 with Tekin RS/8.5, savox 1258, spektrum sr300, glitch buster, transponder, nano-tech 6000mah battery, aka wheels/tires, body and all (race ready) weighs 2168. (zero weight added btw)
