The "Show Off Your Off-Road Wiring" Thread
#16
#18
#20
You have 2x AA battery holders for an aux battery, AND a 10A UBEC???
Why not get something like the BEC Pro and run everything off the same thing? Would save quite a bit of weight I'm sure and allow you to clean that up a bit.
And just curious but looked like it said 3x lipos? How is that working out?
#21
The setup gets complicated:
1) The Data Logger needs 5v input
2) The receiver needs 6v input.
3) No BEC on the HV-110 speed control.
To get 5v, I have the Ni-CD battery wired to the BEC (set at 5v) then into the data recorder.
Yes it used three 4s li-pos in series for a total of 12s. The power setup worked fine, but I was having problems with the pinion/spur gear.
#22
Speed? Theres a local guy thats went 110 w/ a 6s lipo setup
#23
I got around 100 mph during testing. But when I went to the ISC competition I only hit 86mph. I was really disappointed. I had too many problems with my gears always getting chewed up. Its a very high voltage setup designed to be run many many times without overheating. I could do 30-40 speed runs and the motor wouldn't even really get warm.
#24
Holy Smokes!! I've never seen so many Not-clean wired cars in a clean wire thread. Jesus! There was only one or two that was even clean.
My blitz came out pretty nice before I sold it. You all gotta go check out the clean wire thread in the on road section. Get some ideas!
#30
My MP9E with Tekin RX8, 1900 KV motor and two Peak 5400, 45C packs.
