D8Te Setups!!!
D8Te Setups!!!
Anybody have some a good neutral setup for the D8T in electric form.
what kind of track are you racing on? I ran my D8Te at our indoor trophy race last weekend where I TQ'd the second round, and than backed it up on the third round(the only truck to run a 17 lap pace). it was the best my truggy ever felt in a long time on our clay track..
heres my set up
RC Product Designs conversion kit.
tekin 1700kv truggy/MMM ESC
Turnigy 5s 5000 30c
1.2 pistons on all 4 shocks
AE 30w on all for corners.
white front springs
blue rear springs
Kyosho 2.5mm rear sway bar (KYOIF460-2.5)
Kyosho 2.3mm front sway bar (KYOIF460-2.3)
Tekno RC D8T towers Front and Rear
Inside bottom hole on the front and rear towers
Inside hole on the rear hub and front castor block
Outer shock mounting holes on the front and rear towers
Inner shock mounting holes on the front and rear arms
35mm/37mm ride height
5/7/2 oils
Jconcept Blue Sevens with used AKA foams
tire washed and zip-grip2 20 mins before every run.
heres my set up
Turnigy 5s 5000 30c
white front springs
blue rear springs
5/7/2 oils
heres my set up
Turnigy 5s 5000 30c
white front springs
blue rear springs
5/7/2 oils
heres my set up
Turnigy 5s 5000 30c
white front springs
blue rear springs
5/7/2 oils
One thing that caught my eye is your diff fluids. Everything that I've read so far indicates you have to run much thicker fluid for the truggy, but yet you are running what a buggy would use. Can you explain why?
Except for the electric conversion, mine will probably stay pretty stock. How do you like your conversion kit, espeically the motor mount setup?
ben
since the vorza is basically a d8 do you think the battery holder and motor mount will work to convert a d8t
who makes the best kits
www.rcproductdesigns.com
http://rcproductdesigns.com/index.ph...roducts_id=298
some old pictures of my truck running a prototype kit from RCPD before it was released
I love my conversion the motor mount is great I haven't had any problems with motors coming loose or anything like that. the Battery tray is HUGE!(170mm x53mm) all of my current batteries fit along with enough room to shift weight around if needed.
ben
I'll be able to tell you in a few days. I have a Vorza. You will probably need to drill and tap holes for the screws, but other than that, I don't see why it wouldn't work. The advantage if it does work is a fully adjustable battery box that only costs $18 new retail.
ben
ben
Right now, I'm considering either the RC-Monster or Elite RC motor mount. I may get the RC-Monster receiver box too, which can also be purchased seperate.
I really like the battery tray in my Vorza, probably the best design in a long time. I'm also going to test fit the Vorza ESC mount tray as well since I'm using a CC MM ESC, which is identical to the Blur ESC. Looks like there is plenty of room on the D8T chassis.
Since I have these parts, it won't be hard to test fit and find out. I won't make any new holes or anything until I'm sure about where I want things to be mounted.
ben
heres my set up
Turnigy 5s 5000 30c
white front springs
blue rear springs
5/7/2 oils
heres my set up
Turnigy 5s 5000 30c
white front springs
blue rear springs
5/7/2 oils
