need help!! making a 4s lipo
Hi guys I need some help or knowledge?????? OK I got 2 new 2 s lipos packs, I want to make a 4 cell lipo, I already got the cells bare an welded together. And they charge fine. I just need to balance them. I need to geta plug for balance wires.
http://scriptasylum.com/rc_speed/_lipo.html
That's a cool tool that will show you the wiring diagram. You just need to pick up a 4s balance tap of choice.
STOP NOW BEFORE YOU BLOW UP THE WORLD!!!! Sorry, I had to say it! Good to know someone else isnt terrified of these batteries.
thank u
Thank u guys!!!
How would you do this if you had two 2s lipos with the pin style balancers (like Orion)?
have to take out the internal balance board, and re-wire them.
I made one for a pair of those maroon Flightmax hard case packs, which I was going to run in my buggy. I figured if I decided later to run 5S I could buy a single 5S pack, and then split the hard case pair into two 2S packs for 1/10 scale. Unfortunately, while the wiring harness worked great, the frankenpack didn't fit in my buggy with the wires plugged in (it was more than a bit too tall) with the body on.
