Proline Calipers for 1/10 4wd buggy >
Old 06-22-2010, 10:49 PM
  #16
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Thistle View Post
What width of foam did you guys receive with your front tires?
Mine came with the same width as the rear's, which doesn't seem correct. (Tire is 33mm wide, foam is 51mm wide)
Am I supposed to cut them down? If so, what width should I use?
Mine came the same way, I cut a 1/4 inch off mine and they worked fine.....awsome tire for 4wd too
racer1812 is offline
