Speed passion hard to turn
As the title says, i have a speed passion 6.5T and i realized that is very hard to turn. it is pretty much impossible by hand!
When is on the car, obviously the wheels cant spin freerly.
Is this normal for this barnd? I have been using a mamba and i havent had this problem!
Thanks!
Thanks!
Thanks!
Thanks!
What speed passion motor is it V1,v3 the V3 is the newer one and has
plug in bullet connectors and a removable sensor wire. Check the bearings.
If you took it apart recently check make sure the shim si still there. The sensor board does not make any contact with the shaft at all. I would take the shaft out and place it in each bearing one at a time and see if it binds up.
Dynodan22
Dynodan22
Dynodan22
Dynodan22
Thanks everyone for the replys! I have tried to pull it a part but honestly the only thing part i was able to remove was the balck cap on the back! I have removed the 3 short screws on the back and the 3 long ones in the front but nothing is coming off. I tend to belive that the black plate on the back should slide off but it deosnt move. On the other motors i have i can remove both the front and the rear plate but this one do not have a fornt plate.
Cheers!
