Two stage shock pistons
I have been using two stage shock pistons in many of my RC vehicles for years (Revo, 1/8 buggies, SC trucks). They offer superior performance and additional tuning options. Bascially most shocks dampen rebound/compression the same way, oil flows thru the same piston holes. The issue is if you use heavy oil to absorb large jumps, then the low speed dampening suffers. With two stage pistons, which work as one-way valves, when the shock compresses the valve closes acting like thicker oil, when it rebounds the valve opens acting like it has ligther oil. So you can set the oil weight for the big stuff and yet the shock will be responsive over the small stuff. RPM just came out with some pistons for Associated and Traxxas trucks that incorparate this valve system and I ordered a set but have not recieved them yet. I have a Slash 4x4 that I want to try them in. They are supposed to fit stock Traxxas plastic body big bores, and aluminum bodied big bores but you will have to sand the piston down slightly to get them to fit.
Two stage pistons, upper and lower parts.
Valve closed oil flows thru only some of the holes
Valve open oil flows thru all the holes
They work great, I was pleasantly surprised with them.
