Monster issue- please help >
Old 03-10-2010, 01:46 PM
onefast8's Avatar
Trader Rating: 41 (100%+)
Default Monster issue- please help
My Monster V3 is having some issue I cant figure out. Its about a year old and haven't ever had any issues till now. When the switch is "on" it works 100% normal. When I turn the switch off it wont shut off or at least all the way off . It stays on and when I hit the throttle it goes into some protection mode or something, flashing green/yellow lights.
I took the switch appart and cleaned it all out with alcohol as well as the esc.
Reset my radio to it 2-3 times- same issue.Batts in radio and car were 100% charged. Im lost
onefast8 is offline
Old 03-10-2010, 02:17 PM
Trader Rating: 19 (100%+)
Either send it in for a new switch, or cut the switch off solder the 2 wires together and use no switch.
malik is offline
Old 03-10-2010, 02:25 PM
KPitta
Guest
Posts: n/a
Also try a different battery and check all of your solder joints.
I've had one of the presoldered male connectors come apart at the solder joint.
Old 03-10-2010, 03:20 PM
Rampokker's Avatar
Another thing to check, open the case and check the wire that goes to the switch. A while ago someone posted pics of his switch wires that got damaged and the wires were totally exposed. Maybe one of your wires are damaged.
You can also take the switch off and while making sure the wires aren't touching, plug your battery in. If the esc still has a problem, you know for sure that the switch isn't at fault. If the esc stays off like it should, you know it's the switch that's at fault.
Rampokker is offline
Old 03-10-2010, 03:27 PM
jthomas143's Avatar
Trader Rating: 48 (100%+)
Get rid of the switch, it's a pain in the @$$. It is the first thing I do w/ a new MMM.
jthomas143 is offline
Old 03-10-2010, 03:40 PM
Rampokker's Avatar
Personally I like the switch. Mine failed after the first raceday, but I just replaced it with a spare receiver switch I had lying around. No problems with it since.
When you use the traxxas mount for the monster, it has a built in place to mount the switch. Makes it easy to use. Check out the pic:
Old 03-10-2010, 04:38 PM
onefast8's Avatar
Thanks for the replies.
One question, If i elimimate the switch do i lose the ability to recalibrate the radio, since when setting it up you have to start with the switch off?
onefast8 is offline
Old 03-10-2010, 05:14 PM
KPitta
Guest
Posts: n/a
No, you just hold full throttle when you plug the battery in and it goes into calibration mode.
Old 03-10-2010, 06:19 PM
onefast8's Avatar
Cool. thanks
onefast8 is offline
