Tamiya TRF2WD thread
#1397
Anyone have a good setup for 201 on a bumpy, low traction surface that has loose dirt on outside and hard packed dirt down the center?
I have been racing(ugh trying) the 201 since it came out and I can't compete. Our track is pretty tight however I just don't have the traction other cars do. I am the only one running a 201 at our local track. The most popular car is the X-Factory mid motor car.
I just bought some brand new flip-outs to try. Hopefully they make a difference(although I tried some slightly warn ones last week).
I added a bit of weight to the front of the car(about 6 peices of lead).
I currently have 25 wt oil in front with 20 wt in the back.
Front end is slightly higher than rear.
Running ASC brown spring in front and Green in back.
I played around with roll center quite a bit to get more steering in the car but now front end is good and rear end sucks for traction.
Running furthest out hole in rear shocks(on arm) and mid hole in tower.
Running middle hole in front arms and highest on shock tower for front.
That's about all I can think of. Let me know if you have ideas or send me setup sheet to (gwailo12(at)hotmail.com).
Thanks!
Thanks!
#1398
Thanks!
Thanks!
#1399
And link to some set up sheets... although very few for a loose track. http://www.petitrc.com/setup/tamiya/...yaTRF201X.html
#1400
I am sorry to add but I have 3 chunks of weight in the back behind the battery.
At one time I also ran a peice of lead under the entire battery however I didn't notice much of a difference in car response on our track.
I am running a 13.5 with boost. I have a 24 pinion with the stock spur gear(79t I think).
I wouldn't complain normally and I am a decent driver(been racing over 20 years) however the fact I can't get traction really sucks.
When I loosened my slipper a bit it did help however then I couldn't make the jumps.
The X-factory cars seem to be able to jump further and have more traction overall.
Thanks for the tips! I will add more weight to the car, again. I will also copy one of the setups I see here for a 'baseline'.
#1401
I see that they seem to run different pistons in the 'pro setups'.
What hole size is the stock TRF? I see 1.4 x 2 and 1.3 x 2 etc listed in setups.
Also I see a comment about the 'wing'. What does 7" mean and then they circle the number beside it?
Thanks for your help. Hopefully I can get this car to go better!
http://www.petitrc.com/setup/tamiya/...008/Index.html
This is the setup that I am thinking of trying. Anyone know what Pro Line tires he means???
#1402
#1403
#1404
7" is the width of the wing from side to side. You'll see where some guys say they run "full lip" which is the back of the wing (or gurney). Full lip means that the back lip is the same height as the side dams of the wing. More lip means generally means more rear traction.... .
I am currently running 2 deg camber in the rear and 1 deg camber in the front.
I also have the upgrade alum toe in blocks for the rear. I have the 1 degree installed right now.
I see the 'pros' don't use that so I might go back to the plastic for the next race.
#1405
Ahh so they are not running one of the stock wings that comes with the car???
One other thing to try is going to the middle hole on the arm in the rear. Running on the outside may be limiting your droop too much and not allowing the car to roll enough in the rear compared to the front.
#1406
Maybe try Randy's set up here.. http://www.petitrc.com/setup/tamiya/...es20100703.pdf
This is actually very close to where I was going with your set up....
#1408
Definitely having problem with forward bite however also after a turn. My mid corner grip is 'ok' because my speed is really low.
I will move to one of these baseline setups and see where I am at.
I also hope new tires will help(Proline Flip Outs)
