Tamiya TRF2WD thread >
Like Tree12Likes
Old 10-01-2010, 12:13 AM
  #991
sickboy's Avatar
Trader Rating: 75 (100%+)
Originally Posted by afonsospt View Post
When you put cap head screw,shock shaft should be all the way in or out?
all the way up. you are gonna love these shocks. best in the industry.
sickboy is offline
Old 10-01-2010, 12:20 AM
  #992
Originally Posted by hansenhon View Post
hi guys,
do you put any grease onto the spur and pinion gear???
some advice not as it attract dust..
if you do.. what grease to put on??
thanks
Never put grease on the pinion or spur, Grease is a dust magnet. Use a soft brush or air compressor (if available where you run) to remove dust after each run. It only takes a minute and you may come across other areas that need attention.
renjie is offline
Old 10-03-2010, 05:12 PM
  #993
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Where'd everyone go?!?
I've been busy with work the past couple weeks, but going to head to the track on Tuesday for some practice. Need to try out the new arms and gears still. Looking forward to some good results.
Randy Caster is offline
Old 10-03-2010, 05:28 PM
  #994
sickboy's Avatar
Where? OC or WC? I was thinking about Tuesday practice as well.
sickboy is offline
Old 10-03-2010, 06:55 PM
  #995
Most likely OC, I have plans at 6 so I can still get in at least 5 1/2 hours of practice before then since they open at 12...
Old 10-04-2010, 03:24 AM
  #996
whats the thoughts with chassis weighting the 201. tamiya suggests 30grams at the servo if using lipo. rudebits seem to make some really nice weights. is anyone using them, and if so, which? the 32gram servo weight looks like a good idea..
http://www.rudebits.co.uk/
merckx is offline
Old 10-04-2010, 04:04 AM
  #997
mild seven's Avatar
Trader Rating: 63 (100%+)
Im thinking about getting a 201 buggy in the next week or so. just a couple of q's. Do B4 rims fit the 201 or are they mounted differently? pretty new to off road so not sure, what bodies will fit it? will JC b4 bodies fit fine?
mild seven is offline
Old 10-04-2010, 07:18 AM
  #998
im using the 72gr rudebits plate under my servo(racing on grass and cneed to get the nose down big time)im also runing between 60-100 gram on the battery strap,although still playing with this.if you look up lee martins pre euro setup he has the weights he used on the mostly dirt track(which where rudebits)
tony6187 is offline
Old 10-04-2010, 07:20 AM
  #999
b4 rear wheels are a direct fit and you can fit the b4 fronts if you get the optional imperial axles(you will also need b4 front wheelbearings)
you will need to get the 201 body as the b4 body doesnt fit without alot of trimming(basicaly the front of the shell)
tony6187 is offline
Old 10-04-2010, 11:17 AM
  #1000
Haven't seen those weights until now, that's some pretty cool stuff. Wonder if the 511 weights will fit on the 502
Old 10-04-2010, 12:19 PM
  #1001
thanks tony, helpful! is there a set up sheet for lee's buggy or just the pictures to go by? thanks
merckx is offline
Old 10-04-2010, 12:24 PM
  #1002
Lee's setups can be found here -> http://www.trfracing.co.uk/page_1265126433672.html
or http://www.petitrc.com/setup/tamiya/...yaTRF201X.html
Randy's setups are also nice for dirt tracks.
PS:I wonder if 501/511 sway bar will fit 201.Carpet indoor season is coming it may be usefull
afonsospt is offline
Old 10-04-2010, 11:43 PM
  #1003
cool! thanks afonso.
i also tonight drilled out the caps on the dampers and refilled them. it does make a huge difference to their performance, they are now much more buttery smooth with no air cavitation whatsoever. sweet!
merckx is offline
Old 10-05-2010, 07:38 PM
  #1004
Tony Newland's Avatar
Trader Rating: 53 (100%+)
hey all... I'm ordering one up tonight, any key parts that i should have? hopups?
Are there any USA setups posted anywhere?
Tony Newland is offline
Old 10-05-2010, 07:48 PM
  #1005
seankyew's Avatar
the petitrc.com link two posts back has randy caster's setup.
seankyew is offline
