Tamiya TRF2WD thread >
Like Tree12Likes
Old 09-02-2010, 10:33 PM
  #916
cannon's Avatar
Trader Rating: 35 (100%+)
Originally Posted by Eli View Post
Canon i was only being a smart ass, im not bashing on your avatar, i actually think its cool. Agreed 17.5 these days is way fast, but an 8.5 is where its at if you can control it. As far as the weights go i was meaning that atleast i can feel a car with a 13.5 slow a little when you add weight, so i realize 17.5 is competitive so extra weight may hinder some punch and top end. So you may find a good balance between the two. I weighted my lipo set-up and i believe i was 100g under the latest ni-mh. good luck hopefully ill have one soon. Ive been missing some indoor high bite 2wd buggy action, dont get me wrong 8th scale is a blast. ok sry, back on topic
Eli
Not a problem. I will try weighting my buggy but at a lesser level than the Mod cars to see how it goes. To date the 201 has been very good but if adding a little bit of weight makes it better then
As for the avatar ... that was just the baby. Its 12 large relatives were just plain scary
cannon is offline
Old 09-02-2010, 11:00 PM
  #917
Eli
Eli's Avatar
Trader Rating: 15 (100%+)
Originally Posted by cannon View Post
Eli
Well im not saying you shouldnt start there even if it did hinder a little top end you'll make up for it, if it was anyhting like my b4 when i added 70grams under my battery(235g lipo) and 14 up front and rear it really woke the car up as far as being planted, but different car with an 8.5 so there i go getting off topic. anyhow have fun, thats a big kitty =p
Eli is offline
Old 09-02-2010, 11:20 PM
  #918
ifuonlyknew - Tekin v208, there is no throttle profile any more, it is now a timing profile, so if you are adjust TP thinking your changing your throttle curve, your not, your chaging to Timing Profile 4 preset. Hope I am telling you something you already know....
Guys, I thought this was a thread about the TAMIYA TRF201, as I am sure there isn't a Tamiya TESTOSTERONE....
DA_cookie_monst is offline
Old 09-03-2010, 07:12 PM
  #919
Suspended
No there is a throttle profile. You have to go to the throttle tab (circled in Yellow in my included screenshot) and it is the thing that is labled "Throttle Profile" (Yellow arrow). I am not trying to be an ass by posting this just trying to show you that there is a throttle profile.
ifuonlyknew is offline
Old 09-03-2010, 10:23 PM
  #920
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
So while everyone's been on here bickering, I've been wrenching. Got my rides freshly rebuilt and ready for this weekend's JBRL race.
Randy Caster is offline
Old 09-04-2010, 08:59 AM
  #921
Racecrafter's Avatar
Trader Rating: 25 (96%+)
Looking good Randy!
Racecrafter is offline
Old 09-04-2010, 10:15 AM
  #922
Sorry, I should of said, on the ESC, been painting a bit to much of late, to many paint fumes!
Old 09-04-2010, 10:53 AM
  #923
Eli
Eli's Avatar
ya sorry for that, was having a bad day, pops was in the hospital so i needed a little realese. Rides are looking good randy, hopefully have a 201 in a month and can get schooled by you guys some more
Eli is offline
Old 09-06-2010, 12:44 PM
  #924
mandy116's Avatar
Trader Rating: 20 (100%+)
I picked up a used TRF201 and im going over it. When i take off the rear wheels the pin in the axle justs fall out. Should i put some ca on it or something else?? The car looks good tho.
mandy116 is offline
Old 09-06-2010, 01:25 PM
  #925
cannon's Avatar
Do not glue them. Either live with it or you could try seeing if Assocaited roll pins will fit instead
cannon is offline
Old 09-06-2010, 01:40 PM
  #926
I basically shim the axle out so that the pin is snug when installing it. I also use a very small amount of CA on the pin to be sure it doesn't come out.
Old 09-06-2010, 03:01 PM
  #927
CraigM's Avatar
Trader Rating: 34 (100%+)
Nail polish
CraigM is offline
Old 09-06-2010, 03:23 PM
  #928
mandy116's Avatar
I put some ca on a piece of paper and dipped the tip of a x-acto blade and just put a tiny drop on the center of the pin and its nice and snug. Thanks Randy!
mandy116 is offline
  #929
I use a dab of shoegoo to keep mine in place.
JoeGlover is offline
Old 09-06-2010, 04:51 PM
  #930
Glad it worked, easiest fix really. There is a crush spacer between the axle bearings though, so you can shim it tight enough to have the pin fit snug without binding up the bearings at all.
