Tamiya TRF2WD thread >
Like Tree12Likes
Old 08-04-2020, 07:07 PM
  #4876
Originally Posted by WhiteLX View Post
Can I use the DT02/DT03 wheels on a TRF201 if I change out the bearings to 1150 bearings up front and add 12mm hexes in the rear? The original TRF201 wheels seem to be increasingly hard to find and DT02/DT03 wheels being more readily available.
Conversely, is there a metric front hex conversion that does not involve modifying any of the parts?
For the rear wheels, you can use the DB01 12mm hexes (Tamiya 54669) and then use Team Associated B6 rear wheels. The front is going to be harder. IMO, unless you have to have a set right away, look at rcmart or rcjaz. They will have them but shipping will take a while due to the current pandemic.
Mahjik is offline
Old 11-19-2020, 12:27 PM
  #4877
I bought an used TRF201 and thinking of racing him in stock class and sell my xb2c
Now I got some Questions:
1. is there a good front wheel hex conversion kit or option?
2. are there any got upgrade kits still avaible or just the tamiya XM and XR?
3. Which upgrade are must have`s?
thanks
after cleaning and reassemble there will be pics
Sukram is offline
Old 11-19-2020, 12:48 PM
  #4878
The b6 front suspension/hex conversion fits on the 201 series of buggies pretty well, just requires a little shim for the arm at the bulkhead and the ae hingepin if I recall correctly. The flat arms between the two buggies are nearly identical. Most modern buggies run the gullwing arms which would require some modifications to work properly with the 201 kit tower(needs external limiters and more droop on the shock). When I last ran my 211 with the b6 flat or gullwing front end it was very good and easy to drive fast.
trf211 is offline
Old 11-20-2020, 12:03 PM
  #4879
thanks, maybe anybody can give me the numbers of the parts or if there are a kit would be great to get help because AE gots tons of parts and I m not super lucky in finding the right onces
Sukram is offline
Old 11-20-2020, 01:02 PM
  #4880
91672 - hard suspension arms
91670 - hingepin set
31510 - grub screws to hold hingepins
91776 - steering block, caster block
91680 - Ackerman plate
91682 - front axle
91676 - caster hat bushings
There are a few other parts like the hardware but you might have something in your box that will work.
91047 - 6mm ballstud
91049 - 10mm ballstud
25215 - locknut
31531 - 6mm button head screw
31532 - 8mm button head screw
Sukram likes this.
trf211 is offline
Old 11-20-2020, 10:35 PM
  #4881
@trf211 thanks a lot, maybe you forgot but you are awesome! thanks
Sukram is offline
Old 11-22-2020, 05:53 PM
  #4882
WhiteLX's Avatar
There's also this, which I'm going to assume will also work on the TRF 201?
TRF211XM - Jason Moggridge - 12mm Hex Conversion Build
Of course, my luck, it appears the kit is discontinued.
I'm in need of a body for my TRF201. Any suggestions?
Mahjik likes this.
WhiteLX is offline
Old 11-25-2020, 07:59 AM
  #4883
trf201/X or XM/XR/XMW body?
I would like to get an 211 or 201XMW but in europe is it inpossible to find one. I could buy XR and XM kit and tons of upgrades...
Sukram is offline
Old 11-25-2020, 11:43 AM
  #4884
It's not just Europe. Finding those kits is not always easy and when you do, they are priced pretty high. There are three TRF211XM kits on eBay right now for over $600 USD each (one around $650, another around $720, and one around $1000). Unless you are a collector, it's hard to justify getting one when you can get a modern 2wd for half the lowest one with parts availability.
Mitamiya likes this.
Mahjik is offline
Old 11-25-2020, 12:51 PM
  #4885
I would race them, but 600 usd is to high... I got 12 Tamiya cars in my living room displayed but I still drive erveryone from time to time. I love to get the cars I couldn't get in the good old days and build them, race them and tune them... in box collectors are strange people for me
WhiteLX and Mitamiya like this.
Sukram is offline
Old 01-17-2021, 02:24 AM
  #4886
Can anybody tell me the heigth of the N13 Spacer of the N Parts #19114075 I need to check something... thanks
Sukram is offline
Old 01-21-2021, 11:25 PM
  #4887
WhiteLX's Avatar
Any options to the original wing mount? Mine have seen better days and need to be replaced. Would rather get an upgraded part of there is one.
WhiteLX is offline
Old 01-23-2021, 11:38 AM
  #4888
I saw some guys using the original wing mount but cut of the pin and drilled a hole into it and use screws to fix the wing.
Sukram is offline
Old 01-27-2021, 12:55 PM
  #4889
except Painting the body and one missing Wing spacer my TRF201 is rebuilded. At weekend I will made pictures and I hope that N parts are avaible for order the next weeks just need 1 N9 or N10...
If anybody seel exotek extension message me!
Sukram is offline
Old 01-27-2021, 02:20 PM
  #4890
WhiteLX's Avatar
I'm not sure which part number is flat and which is tapered, but the flat one is .075" or 1.90mm. I seemed to have lost one of the tapered ones, which starts at 1.20mm and tapers to 1.80mm and is 18.50mm long.
When I get my new B-parts in, I think I am going to switch to some of the screw down wing buttons like what Exotek sells. I'm also going to run some longer screws through. I've never been happy with the wing mount setup on the TRF201.
Sukram likes this.
WhiteLX is offline
