Tamiya TRF2WD thread >
Like Tree12Likes
Old 06-05-2014, 02:16 PM
  #4426
trx450racer174's Avatar
Originally Posted by lnc0321 View Post
Guys, awesome cars. Here is my recently built DN-01 which I will be running in the stock class at my local track. I am running a speed passion reventon R with a 17.5T. Which motor pinion should I start with? I have a 79T spur.
Thanks in advance.
Here is a pic of my Tamiya
Nice car.
If the trans ratio is the same as the 201 I would start with 32,33/69 assuming your running blinky stock.
Any AE Spur gear will work I used Kimbrough gears when I raced blinky to get the 69T gear.
trx450racer174 is offline
Old 06-05-2014, 02:36 PM
  #4427
Pic of my current setup. Waiting for my worlds car then I will start working on that car.
Old 06-05-2014, 03:28 PM
  #4428
Trader Rating: 72 (100%+)
Nice car trx450racer174
lnc0321 is offline
Old 06-05-2014, 03:29 PM
  #4429
Originally Posted by trx450racer174 View Post
Nice car.
I currently only have a 79T spur. Should I start with a 22 motor pinion?
lnc0321 is offline
Old 06-05-2014, 03:41 PM
  #4430
JoeyE's Avatar
Trader Rating: 44 (100%+)
I am running 5.787 with a 69/31 in 17.5 Blinky Class. You might want to use 79/32 and temp it from there.
JoeyE is offline
Old 06-05-2014, 04:23 PM
  #4431
I don't believe that combo will give you any top end. Just FYI I run 79/23 with a 7.5 and 8.5 in mod buggy.
I suggest you should try to pick up a spur and pinion to run 17.5 with.
79/32????? I don't believe that combo is even possible without extreme motor plate work.
Old 06-06-2014, 05:32 PM
  #4432
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Thumbs up
Ran the TRF201XMW for the 1st time yesterday and WOW!! This this is bad ass!! it jumps really good I was very surprised on how well it did compared to my Centro and one other thing is that this car corners really fast and is very stable!!
The set up did not change too much from the kit setting... just used 35w front and rear with the kit springs which are Yellows rear and ??? front.... (I have to measure them to make sure)... anyways I'll try to get a set up sheet done up or scan'd and posted up... since the Set up sheet has changed a bit over the previous XM setup sheet
JDM_DOHC_SiR is offline
Old 06-07-2014, 02:51 AM
  #4433
AussieTopForce's Avatar
Exactly. As others have said, AE spur gears (B4.1) are a direct replacement. The 79 Spur is modified motor use. Get yourself a 69 or 72 spur (69 recommended) with a 32 pinion. Note anything smaller than 32 with a 69 and you probably wouldn't get a mesh. i.e. you can't move the motor any further forward to get a good gear mesh.
AussieTopForce is offline
Old 06-07-2014, 05:26 PM
  #4434
Thanks!!!
lnc0321 is offline
Old 06-09-2014, 10:54 PM
  #4435
Thumbs up
Lookin' good
Old 06-10-2014, 09:52 PM
  #4436
Raman's Avatar
Trader Rating: 77 (100%+)
Selling a lot of TRF201 hop up goodies
http://www.rctech.net/forum/r-c-item...l#post13327517
Raman is offline
Old 06-11-2014, 07:24 AM
  #4437
That car is too pretty to drive!!
Stevenich is offline
Old 06-11-2014, 02:56 PM
  #4438
Racecrafter's Avatar
Trader Rating: 25 (96%+)
New kit front springs are "black" (Hence no color dot)
Racecrafter is offline
Old 06-11-2014, 08:11 PM
  #4439
Thumbs up
Great... thanks
Old 06-12-2014, 05:42 PM
  #4440
Thumbs up
Finally got the TRF201 Cut Gears back for testing
