Tamiya TRF2WD thread >
Like Tree12Likes
Old 09-24-2013, 05:21 PM
  #4036
gtfour93's Avatar
Trader Rating: 22 (100%+)
Originally Posted by scotty-j View Post
Hey guys, I just ordered a 201 and I am curious as to what upgrades would be recommended for durability? Im not interested in doing any chassis upgrades yet, so anything else that could be recommended would be great.
I did order the 54262 reinforced ball diff gear. Are the hinge pin braces a concern or are they aluminum? I dont have the kit yet, I get it next week but I also have a big race next weekend, so I want to have all the parts I need before that race.
thanks
If you ordered the regular 201, you want to upgrade to aluminum suspension hangers. There are also an XA (3.5mm) & XB (4.0mm) hangers. These give you more degrees of toe in. Not sure if they are included in the 201 upgrade kit. The reinforced front arms are also good to have as spares. I did the big bore spring mod but if you have extra cash to spend, get the Tamiya big bore dampers & springs.
I also added a rear sway bar from a TA03 with TA02 end links. We'll see how these perform on my next track event.
gtfour93 is offline
Old 09-24-2013, 06:29 PM
  #4037
I need a setup for 17.5 tight no big jumps med grip indoor. I'm a very aggressive driver who drives hard brakes & turns at the last minute, almost all of the upgrades aluminum will be using stock foams in front with closed cell rear..... Its a new kit for me..... Thanks guys
Kakenballs is offline
Old 09-25-2013, 10:17 AM
  #4038
Trader Rating: 54 (100%+)
sure would like to see pics of sway bar please
i would recomend the rear upright alum hubs instead of the hangers ...just my opinion ..i have both but ran the stock plastic hangers in mod no probs
if you have money most of the blue crack is worth it lol ...
rkhess is offline
Old 09-25-2013, 11:12 AM
  #4039
Raman's Avatar
Trader Rating: 77 (100%+)
TA03 sway bars are unobtanium... Where did you find those?
Raman is offline
Old 09-25-2013, 02:14 PM
  #4040
Originally Posted by pwrslider View Post
Anyone know if the 501/511 wing mount will fit the 201?
After suffering from LWSS (loose wing stay syndrome) for ages I did this mod... just dont remove too much plastic.
renjie is offline
Old 09-26-2013, 02:24 AM
  #4041
Congratulations to Lee Martin on his 2nd place at the worlds.
renjie is offline
Old 09-26-2013, 05:10 AM
  #4042
madweazl's Avatar
Nice run Mr Martin, thought you had it there! Nice to see Tamiya on the podium.
madweazl is offline
Old 09-26-2013, 09:06 AM
  #4043
gtfour93's Avatar
I took the rear sway bar off of my TA03F Pro. This was the kit stock sway bar. Tamiya & Kawada also realeased versions with more tunable options but those even harder to find.
gtfour93 is offline
Old 09-26-2013, 11:50 AM
  #4044
gtfour93's Avatar
I did this mod by using the existing holes on the wing mounts and installing a piece of carbon fiber rod, held with a long screw and nut.
gtfour93 is offline
Old 09-26-2013, 12:09 PM
  #4045
i need that sway bar ? whos got one ?
rkhess is offline
Old 09-26-2013, 01:33 PM
  #4046
GTFour93, that's a good idea. I'll give that a shot too. My issue was with the screws always coming loose..... probably should try not to spend so much time upside down
renjie is offline
Old 09-26-2013, 02:29 PM
  #4047
gtfour93's Avatar
This worked pretty good but you still need to keep an eye on the wing stays from backing out. Doing both mods together should make it much better.
gtfour93 is offline
Old 09-26-2013, 04:02 PM
  #4048
Autocratic's Avatar
Trader Rating: 26 (100%+)
What body was Lee running at the Worlds?
Autocratic is offline
Old 09-26-2013, 04:36 PM
  #4049
trx450racer174's Avatar
Proline prototype for the MM car
trx450racer174 is offline
Old 09-26-2013, 04:45 PM
  #4050
Where is the best place to buy a trf201? Also the upgrades like the xm chassis and big bores?
cjcoffroad is offline
