Tamiya TRF2WD thread >
Like Tree12Likes
Old 05-24-2013, 04:43 PM
  #3811
Suspended
Originally Posted by memyselfandI View Post
sarcasm is the lowest form of wit champo....
Technically speaking, snappy comebacks is the lowest form of wit.
jonzee is offline
Old 05-24-2013, 04:55 PM
  #3812
Suspended
Seriously guys, you spend too much time worrying/wondering about things that are inconsequential.
And if you take a few moments thinking about things, you could easily rationalize a couple of easy explanations: the car is incomplete, or being as Lee only has the car built up for a pre-worlds race on dirt and his electronics are pulled from his standard mid-motored car ..... or maybe, he's left them that long intentionally so if he changes motor configuration he doesn't have to resolder new wires to the ESC.
jonzee is offline
Old 05-26-2013, 02:56 PM
  #3813
There are some pictures of Lee Martin's 201 alu chassis in the Oople race report for round 3 of the 2013 UK national series - http://www.oople.com/rc/photos/2013national-epr/.
About half way down there is a small feature about it. As one of the captions says, it looks a bit... unfinished!
Lee used his Vega 201 to win the event instead...
Toon is offline
Old 05-26-2013, 09:15 PM
  #3814
Is the ESC mounted on the battery strap? Sure looks that way. Is that the way its done on the other cars?
pwrslider is offline
Old 05-27-2013, 12:05 AM
  #3815
Suspended
I presume, by other cars, you mean the 22, DEX210, and RB6? The 22 comes with Velcro straps, as opposed to a carbon or plastic strap, and the esc has a shelf. The DEX210 mounts the esc in the side pod in rear motor, and on a shelf in mid motor. The RB6 has a shelf of sorts, and a spot behind the battery where a smaller esc will fit. Have you really never seen these cars? I mean like really, like really really?
If I were to get the new chassis (when I get a longer chassis for my TRF201, it will be a trackstar +6mm, not this), I would just build my own shelf.
ifuonlyknew is offline
Old 05-27-2013, 12:48 AM
  #3816
Hahaha. I had a feeling you would be the first to respond the way you did.
Thanks I guess with all your GRAND wisdom. At least you answered the question.
Yeah and by the way I have never really been interested in the "other" cars until now so I have not really looked at the way the ESC's mounted. Hence the reason why I am asking this question among other TRF 201'ers(so to say) who I thought would be more knowledgeable than I and GRACIOUS enough to explain this sort of this thing KINDLY.
I guess I shouldn't ask this type of question on a forum. Whats the point. Right?
Old 05-27-2013, 01:54 AM
  #3817
Fair enough.
I sincerely just thought there would be a sense of camaraderie amongst offroad TRF'ers in all levels. Its been pretty rare to meet others running an offroad TRF locally.
Last edited by Grizzbob; 05-27-2013 at 07:42 PM. Reason: just removing quote that had already been deleted
Old 05-27-2013, 05:33 AM
  #3818
Most people here are cool and have a lot of knowledge. Don't let the trolls get you down. Keep asking your questions.
CTRJ is offline
Old 05-27-2013, 06:31 AM
  #3819
memyselfandI's Avatar
+1
memyselfandI is offline
Old 05-27-2013, 08:54 AM
  #3820
The DEX210 dont have a shelf for the esc, even in mid motor. The bodies are to low. You need to have the esc in the battery compartment or in the side pod.
ridgeracer is offline
Old 06-04-2013, 02:04 AM
  #3821
What non tamiya body fits best, don't mind a little trimming?
Also I built my diff with ceramic balls, I can't keep it from slipping. Is this just one of the diffs that don't play well with ceramic balls? I rebuilt it with the kit balls and its fine and smooth and no slipping.
bhilly82 is offline
Old 06-04-2013, 04:52 AM
  #3822
AaronR's Avatar
Trader Rating: 113 (100%+)
Ceramic balls work well for me.
Bodies made for the B4/B4.1/B4.2 and RB5 work well with some trimming. There should be some photos in this thread.
AaronR is offline
Old 06-05-2013, 10:52 PM
  #3823
Thanks thats what i was thinking, i have seen some of them in this thread. I have seen some of the b4 bodies on clearance. I think i will pick up a few and see how they fit.
Now i do have the exotek 8mm extension on my 201 do i need the extended b4 bodies then as well? I dont think i do but just asking anyway, the stock and the sand viper bodies fit great with the extension.
bhilly82 is offline
Old 06-06-2013, 06:23 AM
  #3824
I built my diff with Avid ceramic balls and have had no issues.
CTRJ is offline
Old 06-08-2013, 02:54 AM
  #3825
That's the same balls I used. Only thing I didn't do was sand the rings when I built it the first time. I guess when its time to re lube it I will try them again with freshly sanded rings.
When I say it would slip, I mean ir would bark from a stand still but once it was moving it was fine just not super smooth. The stock balls are smoother.
bhilly82 is offline
