Tamiya TRF2WD thread
#3721
51540 Big Bore Damper Piston (1.7x2) (4pcs.) - Tamiya Release Date : Jul
51539 Big Bore Damper Piston (1.6x2) (4pcs.) - Tamiya Release Date : Jul
51538 Rod Guide Set for Big Bore Damper - Tamiya Release Date : Jul
54509 Blank Piston for Big Bore Damper (4pcs.) - Tamiya Release Date : Jul
54508 Spring Set (2WD/4WD Rear) for Big Bore Damper - Tamiya Release Date : Jul
54507 Spring Set (2WD Front) for Big Bore Damper - Tamiya Release Date : Jul
54506 Spring Set (4WD Front) for Big Bore Damper - Tamiya Release Date : Jul
54505 Big Bore Damper (Rear 2pcs.) for Buggy - Tamiya Release Date : Jul
54504 Big Bore Damper (Front 2pcs.) for Buggy - Tamiya Release Date : Jul
54503 Aluminum Damper Ball End for Buggy (4pcs.) - Tamiya Release Date : Jul
http://kentech.blogs.se/
#3722
Yeah, I run oval at MMR but for offroad I'll prob run outside again out in Saint Cloud. Can't waste that sunshine. MN only gets like 6 weeks of summer.
Not sure the last time you were down there, but ever since MMR leased out the space next door and built the dedicated offroad track and went to 3 races per week it's been growing pretty well. There were 18 in stock stadium truck last weekend when I went to go see what kits people are running these days. "Hot" for MN at least. Only box-stock slash had more entries (and they always do).
MMR's hot oval class right now is the SK modifieds. Generally draws 12-15 people and we're usually picking up another racer in that class every other week.
#3723
Any pricing info yet?
#3724
tamiya hop-ups are always high if they're sold at full retail.
#3726
Wow July seems like a big month for the 201.
Especially with this new chassis set.
http://tamiyablog.com/2013/04/drawin...01-ifmar-2013/
#3727
#3729
#3730
#3732
#3733
BTW this is what is supposed to be included in the kit
-Aluminum chassis
-Carbon battery plate
-Aluminum battery posts
-Aluminum front posts
-Aluminum rear posts
-Aluminum suspension spacer
-High quality composite side guards
-Aluminum chassis
#3735
Suspended
I'm not too thrilled about it either. I got rid of my 22 last year and went back to the TRF201. For the last 3 months I had my 22, the chassis was slightly tweaked, and it made the car even more sensitive to setup changes. If my adjustments were not ahead of how the track was changing, the car was miserable. The 22 was good before the chassis was tweaked, but it didn't have nearly as wide of a sweet spot as a B4/TRF201 type car. I will stick with my composite chassis, and when I'm ready, will go with a +6mm chassis from track star. Based on the prices of other Tamiya stuff, the chassis conversion should be about $135 street price.
