Tamiya TRF2WD thread >
Like Tree12Likes
Old 01-11-2013, 11:29 AM
  #3436
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
I just checked and my new weighted front bulkhead for the 201 I see if coming off backorder from Great Planes so when our next show order comes in Wed I will have my last part I'm waiting for. Now just need to find a pack of L parts tree and I have most of the spares I would need.
wyd is offline
Old 01-11-2013, 12:21 PM
  #3437
NUZUM's Avatar
Trader Rating: 19 (100%+)
Originally Posted by wyd View Post
As soon as I saw your oils and pushed down a few more times on mine I knew you hit the nail on the head so I know I will be changing my oils tonight before I ever run the car. Your right the rear is just too slow and won't get the weight transferred fast enough with my current oils.
I see you have the 25 degree caster blocks on. What did they do for you over the 30 degree ones on this setup? Since I didn't run my car yet I still have the stock 30 degree on but I have some 25 degree ones I can switch to.
I will look closely at the rest of your setup and print it out as soon as I get to the hobby shop where the printer is working.............unlike my work printer.
25 were great for entry and tight corners... the track i run on there is not alot of high speed corners so 25 were the ticket.. the car just flat out corners now!!!! And has much better balance with full pack for my preference
NUZUM is offline
Old 01-11-2013, 12:25 PM
  #3438
NUZUM's Avatar
Keep in mind im running standard length chassis.
NUZUM is offline
Old 01-11-2013, 12:34 PM
  #3439
trx450racer174's Avatar
Have you drove a lengthened chassis car??? Just curious
trx450racer174 is offline
Old 01-11-2013, 02:06 PM
  #3440
NUZUM's Avatar
No i haven't not real sold on the Exotec kit with added weight and were it is lenghthend.I do have my rear hubs back and caster blocks forward puts it same as RB6 and B4+8 with middle wheelbase settings on them... but the 22 is longer for sure... might try Jimmys +6
NUZUM is offline
Old 01-11-2013, 02:09 PM
  #3441
NUZUM's Avatar
Not saying the Exotec is bad because i just havent tested it but im not fond of alum tplate either... love the cut plastic tplate
NUZUM is offline
Old 01-11-2013, 02:21 PM
  #3442
I was just curious as i have never drove a regular chassis car myself just wanted some feedback if you had indeed compared the two back to back.
I have a +6 Trackstar chassis on my car and i have a newly built 201 with a stock chassis on it just not sure what im doing with that car yet.
Old 01-11-2013, 03:46 PM
  #3443
gtfour93's Avatar
Trader Rating: 22 (100%+)
Here is mine that I raced for the first time at my local indoor clay track. I'm hooked on 2WD buggies.
gtfour93 is offline
Old 01-11-2013, 04:11 PM
  #3444
NUZUM's Avatar
How that +6 working out???
NUZUM is offline
Old 01-11-2013, 04:21 PM
  #3445
NUZUM's Avatar
Lookin good!!
NUZUM is offline
Old 01-11-2013, 04:27 PM
  #3446
I like it turns and jumps great no complaints here.
I run a shorty pack full forward on high bite indoor and move it back 5mm on non high bite.
I dont have any bad things to say havent broken one part yet.
Changed out the front arms to the stiffer reinforced ones and its bueno.
Old 01-11-2013, 04:52 PM
  #3447
gtfour93's Avatar
Lookin good!!
Thanks!
gtfour93 is offline
Old 01-11-2013, 04:59 PM
  #3448
JS
JS's Avatar
Trader Rating: 70 (100%+)
This buggy was dialed at our local track
JS is offline
Old 01-11-2013, 05:01 PM
  #3449
gtfour93's Avatar
... but not the driver.
gtfour93 is offline
Old 01-11-2013, 05:05 PM
  #3450
wyd
Tech Legend
wyd's Avatar
Not a problem. The actually setup I was starting with is for a +8 setup but is still very close to your stock chassis setup except it was a high bite track. Our track is from medium to very high but depends on how its watered and the humidity and temps outside even though we race indoors. If its warm this weekend which I see it will be the track will be very high bite.
wyd is offline
