!/8 scale Electric buggy that has a servo for brakes
Im looking to get into the 1/8 scale buggy. What Im after is that the buggy uses a servo for a brake instead of the motor.
Do the make a buggy that does this or should I do a nitro to electric conversion?
Any help on this would be appreciated.
I heard you can mix a DX3r
I think if your looking to run for long mains it is a good move. If you want to just run a quick 10 minute main then the 100 grams should just be put into more battery. That servo will add about 100 grams to your car so if you running a large pack for that long main then you will gain run time because of the effeciency. If you only run for 10 minutes then you will not gain that run time edge.
does anyone know if theres a servo i can run in a losi 8 conversion with the old novak conversion and electronics. the servos ive tried dont work without a seperate power source. they twitch and lock out to one side. i've tried capacitors as well. any help would be appreciated.
