Gear ratio: 15.3
Old 03-07-2010, 01:57 AM
irishwulf's Avatar
Questions?? Gear ratio: 15.3
I am currently using a 16t pinion with 90t spur for a ratio of 15.3. My question is, is this risky for the engine? The slash manual x'ed this combo out in its gear guide in the manual. I am currently running a 2wd slash on paved road no jumps short straightaway. What's a good ratio for this type of track?
irishwulf is offline
Old 03-08-2010, 12:38 PM
irishwulf's Avatar
Default Combos
I guess what im askin is, does any combo of spur and pinion work? or are there certain recommended pairings?
Old 03-08-2010, 02:32 PM
Well that depends what you mean by "work". Lots of pinion/spur combos will "work" in the sense that your truck will move, but they may not be ideal. There is a range of pinion/spur ratios that will work best with a given vehicle and motor.
Using a 16 tooth pinion and 90 tooth spur will work, but your truck will be under-geared and will be slow, but you'll get quick acceleration and longer run times. Go up to a 19 or 20 tooth pinion and you will probably be much happier with the way your truck runs.
CraigV is offline
