New Caster Fusion EX-1.5R >
Old 04-12-2012, 11:32 AM
  #1726
BigRM's Avatar
It's happened to myself and most of the people I know who own Caster vehicles.
It's caused by the bushing ZX-0086 where execssive wear occurs on the bushing and the plastic around it.
The good news is that after about 10 packs it won't be getting any worse.
BigRM is offline
Old 04-12-2012, 02:50 PM
  #1727
Also good news is you can deal with it by putting bearings there... I will ask my colleague to take photos of solution. I know only that he used some bearings from HPI Baja...
I myself will try to use one part that I hope will solve that problem also...
audriusv is offline
Old 04-12-2012, 05:04 PM
  #1728
cobraman's Avatar
Post
Thanks for the responses. In wiggling things around trying to find the source of the looseness, it doesn't appear to be the bushing ZX-0086, but rather the ball ends and fittings in the steering links and the the servo arm linkage. The play is not excessive in any one connection, but more the cumulative effect of the looseness at all of those connections.
I noticed it last night from the drivers stand during a qualifier while powering into a corner where the inside wheel actually moved side to side slightly. Almost like it was vibrating or fluttering. Can't say that it hampers the handling but it grabs your attention visually.
I'll see if I can do a YouTube to demonstrate what I'm talking about. Not real skilled with the video thing.
cobraman is offline
Old 04-13-2012, 02:20 AM
  #1729
I have changed stock links from servo arm to steering with these (only made bigger holes in balls to fit M3 screws...):
http://www.amainhobbies.com/product_...y-Ball-Links-2
audriusv is offline
Old 04-15-2012, 09:49 AM
  #1730
cobraman's Avatar
Thumbs up
I've pretty much isolated the slop/additional play to the servo arm linkage so I'm going to work on tightening that up. There is play in the steering links as well, but one thing at a time.
cobraman is offline
Old 04-15-2012, 11:19 AM
  #1731
hakmazter's Avatar
Glad to hear you are getting it sorted.
hakmazter is offline
Old 04-22-2012, 09:04 PM
  #1732
godofcable's Avatar
Trader Rating: 37 (100%+)
check out our build article of the Caster Racing EX1.5R!
Stay tuned for our initial review, and our long term review as we campaign this buggy throughout the summer
godofcable is offline
Old 04-22-2012, 09:45 PM
  #1733
kman16jr's Avatar
Trader Rating: 56 (100%+)
Nice review,The only thing i did slightly different from you was the cut the shaft,not too bad,put some scotch 3m double sided tape strips underneath the battery trays and put a dab of ca glue on the screws going to the tray,and i turned the link the opposite way from you and having no issues.I also put one shim on side away from the gear on each diff to shim it.Thanks for doing this review as it will help alot of people out who may have some confusion building the kit.
kman16jr is offline
Old 04-23-2012, 07:20 AM
  #1734
kevin107's Avatar
Trader Rating: 107 (100%+)
Can't wait to see that thing on the track godofcable!
kevin107 is offline
Old 04-23-2012, 07:30 AM
  #1735
godofcable's Avatar
yea I just had a really hard time taking a saw to a brand new perfectly good motor. This way works.
regarding the steering link, It only rubs on the right side. when the wheels are turned hard right, the metal portion of the turnbuckle hits the sway bar end link.
Old 04-26-2012, 07:06 AM
  #1736
Trader Rating: 21 (100%+)
I just finished a build on my new caster EX1.5. The car went together very well despite a problem with the front and rear drive shafts, my kit had three rear and one front. I have to give a big thanks to Rick,Mike and Mikey with caster stepping up and getting the problem resolved very quickly. Mike with Caster racing USA sent new shafts and had in my hand in 2 days. I received a package from China also with a set of shafts and various other goodies. ALL I CAN SAY IS WOW , EXCELLENT CUSTOMER SUPPORT.
wkidder is offline
Old 04-26-2012, 11:32 AM
  #1737
BigRM's Avatar
I had the same thing on my first kit from 2010, but clearance was not an issue with my latest one built last night. Metal parts tolerances and quality are up drastically since I last built a Caster kit. Quality and fit of plastic parts (diff housings especially) still needs to be improved. Overall though, the build process has gone much smoother than last time.
BigRM is offline
Old 04-27-2012, 07:57 PM
  #1738
The caster cars are getting better and better all the time.
bring it on is offline
Old 04-27-2012, 08:07 PM
  #1739
kman16jr's Avatar
Duh rick,Im loving mine especially after today at the track.I went to the track for about 3-4 hours to get some practice time on the buggy before the race on the 12th and 13th and me and my buddy with his mugen were driving almost all day together with no issues and the cars looked the same on the track pretty much.Im very happy with the purchase of the caster and glad to be on the team.I was laying some supa dupa fast laps down today
kman16jr is offline
Old 04-27-2012, 08:10 PM
  #1740
Glad to here that. I also will have mine out soon as I have a new proto type motor I have to start testing.
