Rear toe in hub carriers .5/1.0/1.5 Deg SC10 part numbers >
Old 02-28-2010, 08:43 AM
Default Rear toe in hub carriers .5/1.0/1.5 Deg SC10 part numbers
On the set up sheets from AE they show the team drivers running .5 degree
1 degree & 1.5 degree on different tracks. AE does not show part numbers
anywhere for these that I can find.
Does anyone here have part numbers for all of these??
Chuck 21 is offline
Old 02-28-2010, 08:48 AM
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 167 (100%+)
They use the ones that are available from Racers Edge, they are aluminum and use the large outer bearing like the B44. www.racers-edge.com they make the .5 and 1.0 degree, dont think i have ever seen a 1.5 degree carrier from them.
Matt Trimmings is offline
Old 02-28-2010, 11:10 PM
Thank you for the info. I was hoping for AE parts being avalible as I race
spec truck and can not run anything but AE parts...
Chuck 21 is offline
Old 03-01-2010, 04:15 PM
trerc's Avatar
Trader Rating: 89 (100%+)
They used to make the 1.5 degree rear hub carriers, but they had the standard size bearings. They quit making them quite awhile ago when 2wd stadium truck petered out (before sc). They also use to make a hard ano motor plate, front bulkhead, servo mounts, rear body mount, and front hinge pin brace for the T4, all of which I wish they would make again.
trerc is offline
Old 11-09-2010, 11:32 AM
jboquire's Avatar
Trader Rating: 21 (100%+)
I know this is an old thread but AE now shows .5, 1.0 and 1.5 hub carriers on their webpage. They were originally made for the B44 but the fit just fine.
jb
jboquire is offline
Old 11-09-2010, 12:12 PM
jb
Now if I had the part numbers I'd be in business.....
Thank you...
Chuck 21 is offline
Old 11-09-2010, 12:34 PM
Gigasipke's Avatar
Maybe these:
1.5 degree for the GT2, I have no idea if it will work but looks similar to the B44 rear hubs
http://www.teamassociated.com/parts/details/7932/
Gigasipke is offline
Old 11-09-2010, 12:38 PM
Cameron Kellogg's Avatar
Trader Rating: 45 (100%+)
AE's .05 deg hubs
Cameron Kellogg is offline
Old 11-09-2010, 12:43 PM
Gigasipke's Avatar
I don't actually think the GT2 hubs would work. Looking at the B44 and GT2 side by side I think they have a different offset
http://www.teamassociated.com/parts/...ords=exact_and
I wish they did though, since I want a non-aluminum bolt on .5 or 1 or 1.5 degree rear hubs.
Old 11-09-2010, 01:34 PM
Ae*Driver*70's Avatar
Default AE Is Killer Of All......
Here ya GO .
0 Deg .5 Deg 1 Deg 1.5 Deg
Attached Thumbnails Rear toe in hub carriers .5/1.0/1.5 Deg SC10 part numbers-asc9864_1.jpg   Rear toe in hub carriers .5/1.0/1.5 Deg SC10 part numbers-asc9865_1.jpg   Rear toe in hub carriers .5/1.0/1.5 Deg SC10 part numbers-asc9866_1.jpg   Rear toe in hub carriers .5/1.0/1.5 Deg SC10 part numbers-asc9867_1.jpg
Ae*Driver*70 is offline
Old 11-09-2010, 01:43 PM
1Fastpede's Avatar
Trader Rating: 52 (100%+)
those of you running 0 hubs what toe block are you running?
1Fastpede is offline
Old 11-09-2010, 02:55 PM
RacerMike42's Avatar
I am pretty sure they run the B44 hubs
RacerMike42 is offline
Old 11-09-2010, 04:44 PM
Originally Posted by Ae*Driver*70 View Post
Here ya GO .
Thanks, hard to read though. 9864,9865,9866,9867 if I'm reading them
correctly? Can you confirm please...
Thanks again..
Chuck 21 is offline
Old 11-09-2010, 04:52 PM
1Fastpede's Avatar
Thanks again..
google is your friend. type part# then "hubs"
