t4 arms on a rc10gt ? >
Old 04-03-2004, 07:48 PM
Default t4 arms on a rc10gt ?
Im new to RC tech and looked around a lil bit but didnt see a post or thread that really went into this, can i put the t4 arms on my rc10gt? the arms are longer and just make the ROAR requirments and would make the truck a bit more stable. Would anyone reccomend doing this?
runnin rc10 is offline
Old 04-03-2004, 08:07 PM
http://www.rc10gthobby.com
RC-J is offline
Old 04-04-2004, 12:08 AM
Ybakoff's Avatar
Default Re: t4 arms on a rc10gt ?
Have a look here:
http://www.rctech.net/forum/showthre...threadid=34964
You will find what you want.
Ybakoff is offline
Old 04-04-2004, 03:36 AM
The originator is a guy named JJ Lynch. He was the first to adapt a T-4 front end onto a GT. First mark the holes using the t-4 block.
Now mill down the sides of the GT chassis until it is the width of the t-4's chassis. Center and recenter eye ball and scrutinize now drill the four holes. Now counter sink the holes on the underside of the chassis. AE sells short black posts that are 4-40 tapped on both ends this piece is about an inch long. This will be cut down to size with a cutting wheel. Mount the tubes to the outer two holes of the upper plate for the t-4 steering rack. Mount the front end and mark the holes for the tubes. Remove the front end drill the two holes and try it. I'm going to.
notch is offline
Old 04-11-2004, 08:18 PM
Whats up man!!
thefordmccord is offline
