Sticky Kicks traction compound
#95
no he's not ray ray, he's raydog aka ray f. yes he owns sticky kicks.
#96
Simple green is a degreaser (kind of) so it will make your tires feel sticky as they are just clean. I don't think there is a lot of if any sauce that comes off in the water. RB changes out the water on a regular basis as well. Not everyone uses sticky kicks there as well. A lot of the fast guys do though!
#98
Ray, had a chance to try out the red sauce on pink tired for the main at OCRC on sunday and it worked great. Same traction start to finish!
#102
I just run a small bead of Sticky Kicks on the center of the tire all the way around and then tooth brush the bead to the rest of the tire. I use a wrench to rotate the tire around so I dont sticky kick the fingers. Dont need my fingers stuck to the wheel after all is said and done...
#105
Thanks, Wayboarder. That is the hot ticket you guys. I will post a video on the site in a bit. I just drip it on the tire and massage it in. Some people dip the toothbrush into the bottle and then apply it. Get the tire nice and wet but don't over saturate it.
z50kgin, I run a small bit of gas tube on the brake side of my trigger. Instant traction and no more slippy's. Were all about traction at Sticky Kicks
