Old 07-27-2004, 08:39 AM   #91
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I was really hoping you weren't going to say that.
Jon Kerr is offline   Reply With Quote
Old 07-27-2004, 11:55 AM   #92
Aaron Waldron's Avatar
Hahahaha
It's amazing how much difference a piece of lexan makes. The guys at the shop tried a lot of different things, and this was the best.
Looking good is second priority to winning
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 07-27-2004, 12:46 PM   #93
17driver's Avatar
R/C Tech Charter Subscriber
[QUOTE]Originally posted by Aaron Waldron
Hahahaha
[/QUOTE
Well said.
Midwest malitia member
17driver is offline   Reply With Quote
Old 07-27-2004, 01:11 PM   #94
Jon Kerr's Avatar
I'm mainly an on road guy where we use bodies as much as anything to tune. But I've never really paid much attention to it in off road since normally there isn't much of a "choice." You run the body for that car/truck. I'll do some back to back of my own to see what I can feel.
Old 07-27-2004, 07:43 PM   #95
If you need a little more on-power steering, cut out the holes on the backside of the front shock tower bumps. It will also make the truck jump better.
www.liverc.com
Old 08-08-2004, 08:20 AM   #96
Default Circles
I was wondering what those were for?
But is that ROAR legal.
I have done similar things in TC,and it does make a differene.
Might have to give it a try today at the track.
From The Big Sky Country
SrRC is offline   Reply With Quote
Old 08-11-2004, 12:08 AM   #97
It is only legal if there are scored marks to indicate the lines to be cut. The holes the Associated team drivers have been making in their bodies are not ROAR legal.
www.liverc.com
Old 08-11-2004, 09:27 PM   #98
Default Setup
That is good to know.
Finished forth in the A main in Sundays race.
Truck had way too much steering for me,was running the kit
set up except for inside on the rear hubs.It had much more
steering than the first time I ran it?The problem may have
been too much drag brake from my gt7,will adjust some on
that at Friday nite test and tune.
Do you have anything suggestions on how to get rid of the over
steer-track in hard pack and slick and rough in places,they just
add about 300 ft too track so the surface is not real consistant.
At this time I am setting second in points in stock truck with a
very slight advantage over the third place driver,he finished in
third .
thanks
from the Big Sky Country
Old 08-12-2004, 12:16 AM   #99
What front tires are you using?
Try adding a washer under the front inner ballstud, or stand the front tires up (no camber).
Big Sky country? I have family up there, in Butte. All there is up there is sky!
www.liverc.com
Old 08-12-2004, 01:04 AM   #100
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Aaron, hook me up with some low speed steering!
Old 08-12-2004, 05:15 AM   #101
Drag brake, more negative camber in the front, going out on the front bulkhead or removing washers.
You guys run step pins, right? Ever tried IFMAR pins?
www.liverc.com
Old 08-12-2004, 12:52 PM   #102
I havent tried ifmar pins yet, I usually just try to wear out some of the step pin tread so it wont push so bad. You should come down and race friday man!
Old 08-12-2004, 07:19 PM   #103
Big Sky Country also has air you can breath.
Unless you are in Butte when the smelter is in operation.
I have two washes under the ball stud.zero camber.
Old 08-12-2004, 08:04 PM   #104
Randy - If the track is loamy, I'd reach for those first. You wouldn't believe how dialed they are in electric
SrRc - Try moving the ballstud in on the front bulkhead.
I love driving in Montana..you can go 50 miles and see five cars going the opposite way. I can see five cars on my way out of the driveway.
www.liverc.com
Old 08-13-2004, 01:26 AM   #105
I got an idea, why not stop bieng so scurred of the loamy track and cruise on down here... you can bring some ifmar pins with ya for me to try out
WTB: GTB, Losi XXXT-CR CRFXXXT R/C Items: Wanted to Buy 3 07-19-2008 08:59 AM
losi xxxt mf-2 trx R/C Items: For Sale/Trade 7 03-19-2008 06:17 PM
***** WTB - Losi XXXT CR ******* dgullickson R/C Items: Wanted to Buy 0 01-20-2008 08:31 PM
Losi XXXT!!! racing6 R/C Items: For Sale/Trade 3 08-16-2007 09:50 PM
LOSI XXXT syconate Australian Racing 4 09-22-2005 08:31 PM
