-   Electric Off-Road (https://www.rctech.net/forum/electric-off-road-4/)
-   -   Traxxas Slash Chassis?? (https://www.rctech.net/forum/electric-off-road/361726-traxxas-slash-chassis.html)
steveo knieveo 01-18-2010 04:18 PM
Hey ive been having a problemb with my 2wd slash's chassis breaking in the same spot , where the rear shock tower mounts to the chassis. ive gone through 3 chassis now, and i was wondering what chasis or part i could get/make to re-inforce it . thanks (by the way i have the vxl system in it if that makes a difference?)
if you have a link please post too (: thanks
rally4u 01-18-2010 04:23 PM
i have seen people using a rustler chassis.
ae rat 01-18-2010 04:28 PM
3 of them? stop jumping it off the roof!:lol:
tom_chang79 01-18-2010 04:32 PM
Could it also be the weather? Certain plastic will shatter if you put any stress on it in the cold...
steveo knieveo 01-18-2010 04:32 PM
the first time i was just juming small stuff and hit a water pipe...the 2 last times i didnt even jump it... i had just got the pro line suspension upgrade and i was driving it up and down the street. ( a few rolls ) and when the battery was dead i notied it was broken..
rcuser67898578 01-18-2010 04:33 PM
Dang! 3 wow!
I know there are aluminum chassis on the market. Don't know if that's an option for you but might look into it.
radiojh 01-18-2010 04:46 PM
3, thats pretty hardcore. guess im lucky. i run the bmx track, skate park, and hard bashing on 3s vxl. haven't broke a chassis yet.
Sheldorado 06-14-2010 11:04 AM
Hmm. I've got the Proline suspension kit too. I just broke my second chassis in the same spot.
Hoops 06-14-2010 11:35 AM
Proline makes a chassis brace for that kit. I don't have the link, but I would imagine it's on their site.
Yeti AS3 06-14-2010 11:37 AM
Go to Pro-lines site, they have a plate to reinforce that area to fix the problem. On my phone or else I would get you a link.
Sheldorado 06-16-2010 08:56 AM
I've got two on the way! Thanks guys.
Gouldzilla 06-16-2010 11:30 AM
by chance, are you guys running the rpm rear skid plate that goes from the chassis to the transmission case? locally people were breaking chassis in the same spot because they switches to the rpm and did not put the extra screw in that goes through the chassis and into the skid. they put the screw in and the problem went away. just a thought for you guys. i ran the pro-line kit and didn't have an issue, but i only ran it for 4 runs before i sold the car.
G-Zilla
Officespace 06-16-2010 01:18 PM
From past experience, all Traxxas chassis are prone to breaking, so to save money replacing them, I bought a Fastlane Machines aluminum Stampede chassis (which is what the Slash chassis is based off of anyway) and just bolted on the transmission, a-arms, ect. The only problem I found with this conversion was with the side nerf bars - the Traxxas ones don't fit/work. I solved this problem by getting some nerf bars from a Losi Strike and after a little dremel work, they fit perfectly. Now my truck is basically bulletproof.
And BTW - Fastlane Machines also makes an aluminum replacement chassis for the Slash too.
