Durango DEX210 Thread
Ebb,
If you want front shock towers go to STRC racing. For 10 bucks you can get carbon fibers front shock towers with aluminum camber mounts.
I use the 44mm TiNi shafts with V3 shock bodies and V1 arms. You don't need limiters if you are not using bladders. You can use the droop screws to limit down travel.
Thanks wally, I actually have a bunch of them lol. I've got front towers from Cream, TeamSR, Exotek and STRC that I've been picking up dirt cheap. I just didn't want to disrupt the geometry Fred was going for in this buggy and I wasn't sure if the type B front towers altered it with their swept back design. I was going to use my CF bits for my other 210 that still uses v1 towers/shocks and an Exotek CF chassis, but now it seems I have more options and I can breathe easier lol. I do also have a couple of the Exotek v3 carbon towers that I was going to save for a rainy day if Fred's designed 210 runs out of type B rear towers.
And I appreciate the shock shaft tip! I do run emulsion now so I should be okay doing this I was just going to save the titanium for my old 210, but perhaps I'll throw them on Fred's when I rebuild my shocks again with this newfound knowledge.
Everyone should run a closed bladder system. There is absolutely no situation where emulsion is superior. An open bladder setup is crap so definitely don't try it.
Well Fred, I am kinda limited lol. I have a bunch of shock cap o-rings but I believe I have a total of zero spare bladders for these shocks. Plus, I find the emulsion shocks easier to fill and get consistent. Maybe not as effective on track but so far I haven't noticed a major difference after going emulsion on all four corners. I am going to give the 44mm titanium trick a shot and see if it improves, worsens or stays the same. Thankfully I have the time and strength to do these things right now lol.
Use Losi bladders. They are very easy to build consistent.
Not sure if it applies to the tenth scale shocks (it's 2am and my brain is off) but I've only had issues getting Durango shocks properly setup when I try to use the foam volume compensators in the caps with the bladders. Always too much rebound. The line between you much rebound and sucking air due to not having enough shock fluid is very fine.
The only people that tear bladders are those who run with the bleed screw out, which is a terrible thing to do.
The foam pieces that go inside the bladders are there to equalize the front and rear. You have the same size bladder front and rear but the rear shocks are longer and the shaft displaces more volume inside the shock. You only run the foam pieces in the front shocks for equivalency.
I just got a full set of rear shocks with what looks to be black titanium shafts, aluminum bottom/top caps and preload nuts for $24. I think I have a problem.
I know you guys are way past this but my son has an rtr. hing pin tore chassis so ordered the dimec 20+ 8 i think. it says i need part #td330578 to complete build and two others. i cant find this part anywhere. its new front bulk head any ideas he enjoys this car but dont know how to fix it without parts.
Order the aluminum front bulkhead for 12.95. You won't ever have to replace it again.
For the rest hangers I s he running rear or mid motor??
Is the motor in front of rear axle or behind it?
That's true! I think you can even still get both black and gold versions of it. And some v3 carbon rear towers couldn't hurt for $12 a pop
[QUOTE=WallyRC;14993428]Go to Exotek.com.
Is the motor in front of rear axle or behind it?[/Q the motor is in the rear position
