-   Electric Off-Road (https://www.rctech.net/forum/electric-off-road-4/)
-   -   please help (https://www.rctech.net/forum/electric-off-road/359008-please-help.html)
losi_racer 01-09-2010 07:31 PM
please help
thought i would post here since it involves electric.
My dads 8t 2.0(nitro not electric) has a lipo for the receiver, it has an inline regulator. The lipo and regulator are cut so deans could be put on them both. I soldered them both, no problems on the solder job but 2-3 different times the wire breaks right before the deans. Why is this? again , the solder job is good, its still connected to the deans. but the actual wire breaks right before the deans. it like i took wire cutters and cut one of the wires
20 SMOKE 01-09-2010 07:42 PM
it is probable where the solder flows in the wire and is breaking there
losi_racer 01-09-2010 07:44 PM
and the fix?
losifiend 01-09-2010 07:46 PM
When you over heat wire it gets brittle afterward. The solder makes it non pliable and you are probably bending it to push it in the radio box.
losifiend 01-09-2010 07:47 PM
Originally Posted by losi_racer (Post 6830349)
and the fix?
Use Deans micro connectors since it sounds like the deans is your way of charging it.
losi_racer 01-09-2010 09:02 PM
no to both. wire is ran outside the box.
losi_racer 01-10-2010 11:33 AM
