*ECKO EDITION HYPER 10SC
#18
the AE sct body does look good on the hyper. nice paint job.
#21
now i understand why that flat washers are on the kits!!!
i am thinking using that adapters because i mainly run on a 1/8 scale track always against 1/8 tt nitros...
i only don´t like the space between the adapters and the hub.... is any other way of fit this on hyper? or using slash front ones that space will be eliminate?
sc races here are ocasional and rare...
and it´s more easy to achive good 1/8 tt wheels and tires around here...
thank´s again!!
#22
The front adaptors won't work, it tried it. They can be made to work if you counter bore the inside, otherwise the axles don't have enough threads/length to poke thru the adaptor to tighten the center bolt because the fronts are wider then the rears. So just get the rears or a different brand of adaptor.
Aka are you listening?
#26
i have acess to the machinery that can do that.
i have seen other brands, but aka seem the better ones..
do you know is jeremy kortz ofna driver uses that ones too?
#27
The truck really drives well. I saw the wheels in rc car action and went directly to Amain. That's tight that jeremy kortz runs them also, I love being on the the right path with my truck. I still wonder about the Novac HV motor but I love the 1/10 electronics. 1/8 and 1/10 buggys have a hard time out doing me on my local track during my practice sessions, everybody wants to know what it is. I have been running the lucas oil sc10 body up till now, lol!
#28
I took the dremal to the fenders to get the burrs off a little better. I'm going to make a set of jaws to cut the slots on the adaptors to around .070 deeper with a 3/32 carbide endmill. Should be pretty easy if I run it slow enough, I'll write a quick program for one of the mills at work.
#29
regards
