RC10 body on RC10T >
RC10 body on RC10T
RC10 body on RC10T
Old 12-19-2009, 05:58 PM
MtleyRx's Avatar
Default RC10 body on RC10T
Or vice versa?
I searched and looked at some pictures, but would still like a more definitive answer.
My old RC10T body is about toast and I'd like to put a buggy body on it if I can, so that less dirt/water/etc. will get up into the tub.
I'm sure there's probably a conversion.
Just wondering if its a straight fit to put the buggy bod on the truck chassis or how much it entails.
Thanks for all the input!
MtleyRx is offline
Old 12-19-2009, 06:03 PM
MtleyRx's Avatar
And... as an aside... Why are these "buggy only" tires?
http://www3.towerhobbies.com/cgi-bin...&I=LXDU13&P=ML
I figure if you're looking at this thread you'll probably be able to answer the 2.2" tire on a 2.2" rim question fairly easily. Its just that the description if you scroll down the page says "buggy only". I'm guessing the width is different, but by how much?
Proline does make a similar tire for trucks... but I don't like the tread pattern for my use nearly as much.
MtleyRx is offline
Old 12-19-2009, 07:05 PM
LowClassCC's Avatar
the buggy body for the rc10 will fit on the 10t. justtrim it as needed and your golden.
now as far as buggy tires on truck rims i have to say don't waste your money. you are correct about the width being wider on the truck than it is on the buggy. but you will also need to look at the aspect of the side wall height of the tires also. the buggy tire it a lot lower profile than the truck tire. if you get the buggy tire to fit on the truck rim you will also make the buggy tire lower profile when you are stretching it out to fit the width. so ether stick with a truck tire or use buggy rims also.
LowClassCC is offline
Old 12-19-2009, 07:14 PM
MtleyRx's Avatar
We can always count on a good answers from rctech guys.
thanks!
MtleyRx is offline
Old 12-19-2009, 07:24 PM
MtleyRx's Avatar
Can anyone recommend a rear 2.2 truck tire with very similar tread design?
MtleyRx is offline
Old 12-19-2009, 07:45 PM
LowClassCC's Avatar
those are the pro-line dirt hawg tires. the closest thing i know to them is the pro-line dirt hawg truck tires.
http://www3.towerhobbies.com/cgi-bin...0-00&search=Go
Old 12-19-2009, 08:00 PM
MtleyRx's Avatar
Ya, that was the one I was referring to that I didn't like as much.
This one is a bit different from both but the wife likes it too!
^ Proline Dirt Works
MtleyRx is offline
