Stuck pinion gear >
Stuck pinion gear
Stuck pinion gear
Old 12-19-2009, 11:15 AM
Gopher15's Avatar
Trader Rating: 22 (100%+)
Default Stuck pinion gear
My pinion is stuck on my motor, set screw is almost rounded, any body have any ideas for getting this off.
Gopher15 is offline
Old 12-19-2009, 11:18 AM
Heat it up to break the thread lock if you used any, then use a GOOD new hex wrench not an allen key.
If that fails, drill out the set screw or call the LHS to see if they have a pinion gear puller that you can use.
AreCee is offline
Old 12-19-2009, 11:20 AM
R-E-A-P-E-R-'s Avatar
all else fails you can cut it off with a dremel. Just be careful not to harm you shaft inthe process.
Do you have access to a drill press?
R-E-A-P-E-R- is offline
Old 12-19-2009, 11:34 AM
Gopher15's Avatar
no drill press, i'll try the to heat it up to break the thread lock. I would hate to try and cut it off, since this is a brand new tekin 2050kv motor.
Gopher15 is offline
Old 12-19-2009, 11:44 AM
JeromeK99's Avatar
Just pry it off... everybody thinks they are so tight on the shaft.. but in reality, they are barely on there.. the set screw has such a small point of pressure on the shaft and merely keeps it from rotating. I've done this many many times over the years of racing..
Jerome
JeromeK99 is offline
Old 12-19-2009, 11:46 AM
LowClassCC's Avatar
have you tried a pinion puller yet? you can find them on ebay by doing a search in the rc section for "pinion puller". looks like they run around $14 shipped for a mini and $16 shipped for a standard. worth a try to save from cutting.
LowClassCC is offline
Old 12-19-2009, 11:50 AM
Worst case scenario is that you messed up the shaft and have to replace the rotor. Tekin will sell you one but I don't know how much a T8 rotor would cost. The 1/10 scale Redline rotors are $39.00.
AreCee is offline
Old 12-19-2009, 12:11 PM
Gopher15's Avatar
Thank you all for the help, heat and a unused hex driver did the trick on both set screws.
Gopher15 is offline
Old 12-19-2009, 12:39 PM
Sometimes I know what I'm talking about. (Don't tell the GF, she thinks I'm a dork.)
AreCee is offline
Old 12-19-2009, 01:32 PM
Trader Rating: 21 (100%+)
Invest in a set of good drivers like the MIP Thorp drivers. With mine I can break blue loctite on pinion set screws. Allen wrenches are poor at best.
Glad you got it off.
Duster_360 is offline
Old 12-19-2009, 01:36 PM
MIPs are very good and also Hudy, AE and Losi. Integy on OFNA are just so-so.
AreCee is offline
