Another question for you 1/10 scale guys- >
Old 12-19-2009, 09:36 AM
Vision450F's Avatar
Trader Rating: 19 (100%+)
Default Another question for you 1/10 scale guys-
Hello-
Whats a popular tire for an indoor, hardpacked, and slighty damp track? I currently use taper pins on my 1/8 buggy (pink compound)..... Should I use similar tires on my B44? I just to get some feedback from experienced racers.
Thanks,
Jim
Vision450F is offline
Old 12-19-2009, 10:36 AM
bboard's Avatar
Yes, you will run similar tires. At our local indoor track Pink Taper pins are also the favorite on e1/8. On 1/10th scale Losi Taper Pins(Pink), Panther Switch(SS)...etc..., and slicks are the favorite. Traction compound is also your best friend. Our track is a hard-packed and kinda greasy.
Your best bet would be to see what other drivers like on your track.
bboard is offline
Old 12-19-2009, 03:15 PM
OG RC 10T's Avatar
Trader Rating: 41 (100%+)
I used Double Dees on the B44 and now on my eRevo. Right now Jconcepts has them on sale (all 4) with rims for $30 - for truggy.
OG RC 10T is offline
Old 12-19-2009, 10:56 PM
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
JConcepts Gold Bar Codes seem to work great at all the indoor track around me...
Frank Root is offline
Old 12-19-2009, 10:58 PM
tom_chang79's Avatar
I'm gonna have to try that sometime. Does JC make Bar Codes for 4wd fronts as well?
tom_chang79 is offline
Old 12-19-2009, 11:03 PM
TLRacing
Frank Root's Avatar
Yes, 2wd, 4wd front, and buggy and truck rears, not to mention 1/8.. so they have you covered!
Old 12-20-2009, 04:33 AM
klaymon's Avatar
Trader Rating: 71 (100%+)
I use pink Taper Pins on the buggy and truck early in the day while the track is wet. As it dries out, I switch to pink BK Bars on the buggy and blue Bar Codes on the truck. It stays dialed pretty much all day that way.
klaymon is offline
Old 12-20-2009, 05:17 AM
R/C Tech Elite Member
CCristo's Avatar
Trader Rating: 56 (100%+)
Originally Posted by Vision450F
Hello-
Thanks,
Jim
Do you race at RCE? For 4wd, pink BK Bars in the back and pink tapers up front are the tire of choice with bomb1/And-1 foams.
CCristo is offline
