B44 lipo setup??
Old 12-17-2009, 08:22 PM
drive2survive's Avatar
Trader Rating: 23 (100%+)
Default B44 lipo setup??
read somewhere on here where you can convert the saddle pack so you can use lipos...any info on that??
drive2survive is offline
Old 12-17-2009, 08:25 PM
nelson6500's Avatar
Trader Rating: 49 (100%+)
they make lipo saddle packs.
nelson6500 is offline
Old 12-17-2009, 08:33 PM
Trader Rating: 21 (100%+)
reedy 5100 #710 use the lipo brace and your money
toyota 2jz is offline
Old 12-17-2009, 08:46 PM
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
I have that Reedy 5100 pack and its been great , always balances out even and barely gets warm during a run with a 5.5T motor .
BashemSmashem is offline
Old 12-17-2009, 08:47 PM
yes indeed mine never get warm at all couldnt ask for a better battery
Old 12-17-2009, 09:04 PM
Unless you are at a ROAR race or a race track that requires you to charge in lipo sack then you don't need the lipo specfic tray. Just use servo tape to tape the battery to the chassis and the top brace.
Here's a hobby city saddle pack:
http://www.hobbycity.com/hobbycity/s...idProduct=9967
kcobra is offline
Old 12-17-2009, 09:53 PM
Trader Rating: 515 (100%+)
I have 2 of those batteries that I'm going to try out at the track tomorrow. I also have a MaxAmps 6000 and Reedy 4200 saddle packs. The Reedy packs are very good quality. I will post up tomorrow about the FlightMax 5700's.
QDRHRSE is offline
Old 12-18-2009, 12:46 AM
The Fox's Avatar
You can use lipos, you need the Lipo Cradle #9785.
I am using the 4900mAh 25C SMC packs and they work great on my B44 with a 10.5.
I know that the Hobby City packs work good, but a buddy got a few and all of them went bad with only 5-10 charges on them. They all broke internally.
Nick
The Fox is offline
Old 12-18-2009, 01:17 AM
Bugle's Avatar
Yeah I wish they would make those in 2S2P to get the height and weight down..
Bugle is offline
Old 12-18-2009, 02:23 AM
tom_chang79's Avatar
Holy cow, 3P. No wonder they are 5700maH. It's three 1900mAH in parallel stacked in series per side... The 2S is when you hook up the two sides in series?
You're right, they should just use two in parallel, but using higher capacity cells. Two 2500mAH in parallel to make 5000mAH would be sufficient...
tom_chang79 is offline
Old 12-18-2009, 08:57 AM
Chimer's Avatar
Trader Rating: 26 (100%+)
You really don't need the LiPo Cradle. You can just tape the batteries to the battery straps. Remove the plastic battery trays, you won't need those for a LiPo. Depending on which LiPo you choose you may have to put spacers under the battery strap posts and use longer screws according to the amount of spacers used.
Chimer is offline
Old 12-18-2009, 09:12 AM
maybe you can post a pic of that setup thanx
Old 12-18-2009, 09:44 PM
I love the 5700mah FlightMax packs from HobbyKing. My B44 went for at least 40 minutes today if not longer with a 9T motor before they went dead. I have 2 B44's and one uses a different sized lipo which is lighter and has weights all over it (the B44). With the 5700 packs I do not need any weights and the car feels very balanced. They are way better than the soft MaxAmps pack that I have. The only downside is that you need to notch the upper chassis a bit to clear the inside battery wires.
QDRHRSE is offline
