Aftermarket B-44 topdeck? >
Old 12-13-2009, 06:14 PM
Default Aftermarket B-44 topdeck?
Today I broke the rear topdeck 2 times at the ballstud mounting point. it seems that it would be a simple fix to leave more material surrounding the area where the ballstud hole is drilled. Does anyone make a top deck with more material surrounding the holes?
Thanks in advance.
Brian
losi b is offline
Old 12-13-2009, 06:34 PM
Trader Rating: 15 (100%+)
The new rear deck should have more material. I had the same problem with the front deck and what some ae guys told me to do was use a washer under the nut on the top of the plate. It needs to be a bigger washer as it adds strenght to that part of the top deck. Hope that makes sense.
dbracn is offline
Old 12-14-2009, 06:34 AM
Bad Company's Avatar
Trader Rating: 136 (99%+)
Has anyone tried/raced with Diggity flexxy top plates for the B44? If so what did you think?
Bad Company is offline
