Slash setup, help?
Exactly as the title says but I need a setup for hard packed clay! Anyone got one? Im usin soft bow-ties in rear and medium up front:nod:
You want soft tires for that, you're set up properly, don't sweat it.:D
Sure, your tires sound good.
Shocks in outside hole in front arm, 3rd hole out in rear. Go in 1 hole on all arms for outdoor and stiffen shock oil by 10-15 for outdoors. 35 wt front, 25-30wt rear. The further out on the rear arm you go the softer your shock oil choice needs to be 2 degrees front camber, 3 rear 18 tooth pinion indoors, 19-20 outdoors keep the Titan oiled up well. Some of the faster racers have been blasting the endbell with wd40 alot, then adding more lube to the bushings. 20,000wt diff fluid lightly packed into rear diff. Don't fill it all the way up. Battery in the middle or forward positions 1-2 degrees ft toe out ride ht: Ft arm slightly below level, rear level with the front. spend some time tweaking the slipper |
Here is the Setup I use for my Slash. It seems to be pretty good.
http://www.traxxas.com/PDF-Library/K...up_slayden.pdf Here is the Blank setup sheet so you can document what your doing to your truck. http://www.traxxas.com/PDF-Library/K...etup_blank.pdf |
thanks guys!!
Originally Posted by traper285
(Post 6707173)
