Old 03-15-2004, 11:20 AM   #16
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Yes, you will. The newer arms have differnt geometry than the older arms that the RPM arms were based on. Plus RPM plastic is very flexy and springy. Not good for suspension component.
Jack Smash is offline   Reply With Quote
Old 03-15-2004, 01:08 PM   #17
Steve Nelson's Avatar
I USED THE T4 INLINE AXLE WITH THE STOCK GT STEERING/CASTER BLOCK ASSEMBLY. I HAD TO REAM OUT THE T4 INLINE AXLES TO .125, THIS MAKES THE FRONT END APPROX. .060 WIDER PER SIDE. THIS ALONG WITH THE B4/T4 AXLES IN THE REAR WILL HELP STABILITY, BUT MAKING THE FRONT MUCH WIDER THAN THIS, WITHOUT MAKING THE REAR MATCH WOULD NOT HELP PERFORMANCE MUCH.
Steve Nelson is offline   Reply With Quote
Old 03-15-2004, 09:42 PM   #18
Ybakoff's Avatar
So how did you find that it went.
Also can you post some pics.
Also I know I'm asking alot sorry. Can you maybe put a required parts list on here. I have to order from the states. Don't want to miss out on any thing. Bummer when your order arrives and your missing one part.
Ybakoff is offline   Reply With Quote
Old 03-16-2004, 02:30 AM   #19
Ybakoff's Avatar
Has anyone ever had a problem with the idler gear. It must of locked up some how and the topshaft ripped all the teeth of it. Just curious. I'll post some pics when I get a chance. And it has to happen with a minute to go and your 1/2 a lap in front.
Old 03-16-2004, 05:26 AM   #20
KINGZJ's Avatar
Send a message via AIM to KINGZJ
You have "the" problem. I would sugest replacing the tranny case and all the bearings and the top shaft. Use all asc parts. This is the only way to stop this problem cause once you have it, it doesnt go away until you replace the tranny case. Parts are cheap and it will be bullet proof again.
KINGZJ is offline   Reply With Quote
Old 03-17-2004, 03:08 AM   #21
ScoopGrate's Avatar
hey sounds like a stupid question but does it matter what side the arms go cause on the rpm it has L and R and the b4 have the same so.........
ScoopGrate is offline   Reply With Quote
Old 03-17-2004, 10:02 AM   #22
Send a message via AIM to rcracer37
yes it does.
rcracer37 is offline   Reply With Quote
Old 03-17-2004, 02:16 PM   #23
Ducati-Rider's Avatar
Default RC10GT Gearing Alternatives
I'm coming from an electric background where gearing is everything. Has anyone fooled around with different gearing combos on the GT or is the factory ratio pretty much ok?
Seems that the nitros have so much HP that gearing really doesn't matter that much, or does it?
thanks
bill
Ducati-Rider is offline   Reply With Quote
Old 03-17-2004, 02:27 PM   #24
If you use the gpm aluminum case you will never have the problem again.
DYNO94 is offline   Reply With Quote
Old 03-20-2004, 03:00 AM   #25
Default GT plus
I just got the GT Plus. I got some cvds some diff bearings actual associated springs and some thirty seven and a half and that thing is wicked! i am still waiting for my robinson racing idler gear and i need to bolt that rear pivot block. Associateds are dialed.
I know this one guy who put the whole front end of a T4 on his GT.
notch is offline   Reply With Quote
Old 03-20-2004, 07:48 AM   #26
Ybakoff's Avatar
Where can you get it from. That will ship to Australia.
Thanks Ybakoff
Old 03-20-2004, 07:53 AM   #27
Ybakoff's Avatar
Default Re: RC10GT Gearing Alternatives
thanks
bill
I went one bigger on the clutch bell, and it was a real dog out of the corners. I wouldn't mind trying one smaller but I havent have time to play. On the 3 tracks around here the gearing I guess would be quite close. I reckon Assoc have got it sorted from the box.
Old 03-22-2004, 06:15 AM   #28
Thanks Ybakoff
Try Hobby Etc.com, the p# is rgt1306 in stock.
Old 03-25-2004, 08:22 PM   #29
Default picture of my factory team
Here is a picture of team gt with body off. I would take pick of body but waiting for new body to paint old one is bashed.
I just took it apart and cleaned and checked everything out for this season, still have to put wires where they belong.
Old 03-27-2004, 01:40 AM   #30
Ybakoff's Avatar
How do you find the T4 wheels on your GT. Do they change the track at all. Wider etc. Or are they the same offset.
