HOW TO CHECK LIPO VOLTAGE >
Old 11-29-2009, 04:15 PM
Default HOW TO CHECK LIPO VOLTAGE
Hey guys i was wondering how to check lipo voltage using a voltmeter... thanks again
VslaXshL is offline
Old 11-29-2009, 04:37 PM
Justin B's Avatar
Trader Rating: 18 (100%+)
How many cell lipo battery are you talking about?
Set the volt meter to check voltage red wire to red wire, black to black and you should be fine.
Justin B is offline
Old 11-29-2009, 04:38 PM
Trader Rating: 21 (100%+)
Pos to pos and neg to neg on main leads - that will give you total voltage. Depends which balance tab you have, but can place pos from dvm on the metal part of one of the balance wires (exposed in the balance conn itself) and then touch one other - that is cell voltage for one of the cells. Move the neg to the next and its the next cells voltage, etc for the rest. Be careful not to let your dvm probes touch - direct short!!
JST type balance conn is diff - have to more both pos and neg over one position each to see all the cell voltages. Check it out, you'll figure it out in short order, its taken way longer to read this than to do it.
Duster_360 is offline
Old 11-29-2009, 04:46 PM
Super Moderator
Use the DC voltage setting on the meter (not AC).
Dave H is offline
Old 11-29-2009, 05:24 PM
Ill be using a 3 cell lipo i get using how to connect the pos to pos and the neg to neg whats the other stuff your talking about sorryyy
VslaXshL is offline
Old 11-29-2009, 07:15 PM
Wait im so sorry im not understanding you but whats the dvm what if they touch with a direct short and how do i find each cell voltage not total cell votage
VslaXshL is offline
Old 11-29-2009, 07:27 PM
DVM = Digital voltmeter
The probes on my dvm have about 1/2" of metal at the end of the leads - don't let them touch while you're trying to get the voltage or it will be a short (sparks). You can get voltage of the individual cells off the balance tab by using the voltmeter probes across different balance wires.
Old 11-29-2009, 07:33 PM
jmcvicker's Avatar
This is how using a Electro-Tek meter.
- set to DC
- set to 20V scale
red on red, black on black (no touching...) Showing 3S Lipo being tested with 11.55 v
jmcvicker is offline
Old 11-29-2009, 07:40 PM
when im looking for indvidual cell voltage do i have to ground it to anything with the black wire on the volt meter
VslaXshL is offline
Old 11-29-2009, 07:46 PM
No, both probes are on the balance tab. What style balance connection - they are wired differently.
Old 11-29-2009, 07:50 PM
jmcvicker's Avatar
Tell us about your charger - does it (or not?) have a voltage per cell display? If you are charging lipo - should be using a Balancer of some type and many chargers now (even the cheap ones) tend to have plug in balancer adapters which can display the voltage per cell.
Old 11-29-2009, 08:43 PM
its a commom sense rc balancer they sell another one too that shows the voltage but i dont have that one until i buy one of common sense's cell spy's ill have to use a voltmeter
VslaXshL is offline
Old 11-29-2009, 08:52 PM
I assume your voltmeter has some kind of leads, correc? Touch any two of the balance wires at the balance plug - they are exposed here and see what voltage you get. Experiment, just make sure not to let your voltmeter leads touch while they're in contact with the balance connector.
Old 11-30-2009, 03:48 PM
all rightyyy thatyou all for all the replies
VslaXshL is offline
Old 11-30-2009, 06:03 PM
Cool, glad you got it!
