Old 09-28-2005, 05:07 PM   #511
W.E.D.Jim's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to W.E.D.Jim
A note to any XB8 owners, when biulding the shocks, pay close attention to the small washer that goes UNDER the shock piston. I thought i'd be smart and put it above the piston thinking it would keep the shaft and nut from pulling thru the piston, but the piston was able to wobble and wear out in the center causing some strange damping.......New pistons and a set of washers later the shocks are buttery once again!...., Jim
www.wedjim.com ...Reopening soon. I'm still painting, just not with 40+ bodies waiting. :)
www.prolineracing.com
www.HarleyDavidson.com
"Nothing but the best!"
W.E.D.Jim is offline   Reply With Quote
Old 09-29-2005, 01:48 AM   #512
speedy2's Avatar
new TQ euro suspension sets seem to do the trick
xb8 is driving much smoother
thank you Yannick...
speedy2 is offline   Reply With Quote
Old 10-06-2005, 04:13 AM   #513
speedy2's Avatar
the Buggyman
WED Jim
how do you feel about your XB8 now ??
Old 10-06-2005, 06:34 AM   #514
W.E.D.Jim's Avatar
speedy2, i'm still enjoying it, i've solved my only issue, which was my own fault. I do wish X ray would have some machined pistons so I didn't need Mugen pistons in my shocks. Since they have addressed every other issue that came up since it's release, i'm sure it won't be too long.
The car handles great and feels quite a bit like a cross between my 7.5 and MBX5, maybe that was their intention?..............., Jim
Old 10-10-2005, 06:48 AM   #515
Default Pivot Ball
Anyone know of an competitive option for the pivot ball on the front upper arm ball joint for the XB8R. My hobby shop is out. I think I recall a posting on this somewhere but can't find it.
Cheers
Ranlod is offline   Reply With Quote
Old 10-10-2005, 06:53 AM   #516
Aaron Waldron's Avatar
duh
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 10-11-2005, 04:09 PM   #517
the buggyman's Avatar
I really like the Xray. I have had zero problems and love the adjustability of the car. I have a good set up right now and the car is like it is on rails. I like it a lot...
the buggyman is offline   Reply With Quote
Old 10-11-2005, 07:06 PM   #518
W.E.D.Jim's Avatar
Ranlod, i'm not sure of anything else that would work. I would bring the part to the shop and check out other brands for possible solutions. Or try another shop for the exact X ray part........Jim
Old 10-12-2005, 08:25 AM   #519
Thanks Jim.....
Old 10-16-2005, 12:44 PM   #520
Canuck's Avatar
Trader Rating: 25 (100%+)
Thinking of installing a Novarossi engine in a XB8R. What model of engine would you recommend I put in it?
Is there a standard for a class in buggy racing?
Canuck is offline   Reply With Quote
Old 10-16-2005, 02:22 PM   #521
JusBox's Avatar
I have a S5 in my XB8, you can always swap out the piston/sleeve for the S7 piston/sleeve for around 90 bucks when you wear the originals out.
JusBox is offline   Reply With Quote
Old 10-16-2005, 02:27 PM   #522
Canuck's Avatar
Reason why I was asking about Novarossi is because I have access to a free .21 and was wondering wich model I should get.
Also is turbo a good idea or a pain in the &&#@($&* on the tuning side of thinhgs?
Old 10-16-2005, 07:51 PM   #523
Hey Canuck
You can't argue with free. If that doesn't work go RB.
JOKER
JOKERRACING is offline   Reply With Quote
Old 10-16-2005, 07:53 PM   #524
As far as the Turbo, some manufactures say no no for offroad.
JOKER
Old 10-17-2005, 05:56 PM   #525
W.E.D.Jim's Avatar
Canuck, a turbo will work fine, if it has a good carb. The only difference is the plugs cost more money, since they are precision machined to seat in a taper in the head button, rather then using a bronze washer to seal them.
A turbo plug equipped engine actually doesn't make more power because of the plug, other then the fact it sits nice and flush inside the combustion chamber. they make more power because of more aggressive porting that is usually done in a turbo plug equipped engine.
I like the P5X I have in my XB8, it was modded by Maxy of Maxys fuels......, Jim
XRAY XB8/XT8 THREAD 20 SMOKE Nitro Off-Road 404 04-23-2014 06:32 PM
Xray Thread (EP,GP On & Off Road) Andrew Barr Australian Racing 100 12-24-2007 06:32 AM
XRAY XB8EC THREAD pink_sleeve Electric Off-Road 82 08-01-2007 08:28 PM
Xray M18T/MT/NT Thread thachowman Micro and Mini Scales 2 10-31-2006 08:28 AM
Xray M18T Thread!!! LosiFromHell986 Electric Off-Road 10 10-15-2004 01:51 AM
